Stupid question… ceramic coat the underside?
AGM Everglades
Everglades
Los Angeles
5 early broncos, AGM Everglades
Everglades
Any benefit to ceramic coating the undercarriage/frame? I’m not well versed in CC but I know it makes water/mud/sludge literally roll off paint so would it help to keep the underside clean?
Teke
Colin
01 Mustang Cobra
Fluid Film it. You have to upkeep ceramic coatings which would be a pain under a vehicle.
Desert_Brush
SoCal
2015 Mini Cooper
What is "Fluid Film" and why does it require less maintenance than ceramic coating?
BigHoof
PA
Ram 2500
Just watch where you spray the FF. It WILL cause rubber to expand. Especially rubber seals like around your doors that get hit when the FF drips out of the drain holes. Has a stink to it also, almost like BO.
I may go with the NHOU stuff this go around. They have both clear and black.
Teke
Colin
01 Mustang Cobra
It is a lanolin based rust inhibitor and lubricant. Spray it on once a year or so and forget it. You can’t get ceramic coating in all the crevasses and inside the frame like you can with fluid film (or any other undercoating spray). Ceramic coating also relies on maintenance boosting products to fill in any scratches in the ceramic coating. It just isn’t meant for underbody
Teke
Colin
01 Mustang Cobra
Correct, just don’t spray your non-oil resistant rubber and plastics. Personally never had an issue with it but I’ve read people have had issues. There are other products out there but I have no experience with them.
BigHoof
PA
Ram 2500
Around the doors is the main place had issues. Caused the rubber to swell then it looked wavy. My rear plastic fenderliners (pickup truck) also got funny in that the FF warped them some. The product itself seems to hold on pretty good considering it can be washed off with pressure.
Desert_Brush
SoCal
2015 Mini Cooper
Sweet, thanks!
