storage in rear floor
ZackDanger
Z
Massachusetts
2021 Toyota 4Runner
I guess they thought people buying the high package wouldn’t get the winch. Are the 360 cameras linked with the front cam? I don’t know. Poor engineering anyway. Especially the bull bar covering up your signature branding.
I think the 360 cameras are linked with the front cam only in the sense that without it, it's a "270 camera" system.
Headsong
I think it's pretty obvious that the slide out tray is not permanently bolted down, and can swing up or unlatch and be moved.
The slide out tray really is just a flat accessory that sits on the cargo floor. It might not even bolt down, which would explain why there isn't one for the 2-door... it's not deep enough to be able to support the weight of a person sitting on the end of it.
I remember someone (who might have insider info) mention something about a "twist lock"... but I'm not entirely sure if that was based on observation or a guess.
There's another thread with pix of both naked and with the slider. We understand that it's removable since THE JACK IS UNDER THERE!!
Aman
Aman
Northern NJ
I really don't think they thought about it at all. Esteban told me that the camera is not blocked by the winch. I questioned him on it and he waffled a bit. Scary that the brand manager didn't have a clue. :rolleyes:
Halfsmoke00
Kenny
Illinois
'09 Ford Escape AWD V6, '91 Plymouth Acclaim V6
This is the 2-door.
I haven't seen a picture of the 4-door yet.
I wonder if thats enuff space for a small 3 or 5 gallon fuel cell. That would improve the range of the 2 doors smaller gas tank.
Ramble_Offroad
Nels
Northern CO
2014 2D JK on 35’s
It doesn’t look like there is enough room, but I’d love to be able to mount a compressor & aux battery under the floor. Something like this.
https://americanadventurelab.com/product/jeep-jl-dual-arb-compressor-mount/
That way we could have on board air & a dual battery tucked away. I seriously doubt there will be room under the hood. Let’s hope I’m wrong.?
PEACE
Judge Rufus
Wheeler
Colorado foothills
Infiniti QX80, GMC Sierra, Mercedes SLK32 AMG,
I'm pretty sure it will be a PITA to get to the storage under the slide out tailgate. The portion of the tailgate that's inside the cargo area is bolted down covering up the lift up storage hole. So if you need to get to your jack that you left in the storage compartment, you better hope you brought a wrench to take out the entire tailgate assembly so that you can get to that compartment.
Mango&Moose
SE USA
Scion xB / Toyota Sienna. RIP my 96 Ranger Splash
Here is hoping:
You slide out the tailgate and then can lift the "floor" up and can access below.
Headsong
Here is hoping:
My recall is that there were some quick release toggles of some sort. I don't think they'd make it hard to access....
Bohlmbo
Bob
St. Louis
2021 Bronco, 1966 Mustang, 2014 Jeep Wrangler
The other thing to remember about the rear storage is that it is the only place (outside of glove box and center armrest) that can be locked when your truck is parked with the top and doors removed. At least this is true with my Jeep JK.
It sounds dumb, but I make sure to remotely lock the Jeep with no top and no doors so that the back tailgate is locked. When the tailgate is locked, you can't access the rear storage.
Judge Rufus
Wheeler
Colorado foothills
Do jeeps lock feature come with some sort of force field surrounding the cargo area preventing people from just reaching over into the cargo area?
Ford Bronco storage in rear floor 1609962526218
Headsong
Don't be too sure until we see more. It might be a simple pull handle from inside that isn't interfered with by the door. So keep your gold or guns there.
Philly
Dallas, TX
2022 JL Rubicon
The panel that covers the storage compartment extends under the tailgate door so that you cannot open it without opening the tailgate. If you worked hard enough with a pry bar, you could probably rip the panel off without opening the tailgate door, but that would probably draw a decent amount of attention and most people don't know about the storage compartment to begin with.
AK SNO RIDER
Ty
Alaska
You guys are overthinking this whole slide out tailgate dilemma. In order for it to be a problem, Ford would actually have to bother to MAKE the damn thing, which they seem incapable of doing thus far.
