604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
Chonky boi deciding if he should get the McDoubleBaconMapleSyrupSlammer burger, or the salad...
okbob
North of the Red
71' u15, 66' u14, 66' u14
These suckers are little fatties. Quite a bit heavier than my EB with V8, NP435, Dana 20, Dana 44, Dana 60, steel bumpers, steel body, steel wheels, etc. Not sure where the '21 is keeping all its weight.
IIRC my 71' with steel bumpers, steel wheels 36" swampers, 302, np435, dana 20, dana 44, Ford 9", winch, cage, full 23gal tank is 4750lbs
NotApplicable
BEVs
What is the weight of the 4-door? The 6,000-pound vehicle tax deduction is a rule under the federal tax code that allows people to deduct up to $25,000 of a vehicle's purchasing price on their tax return. Maybe ill buy a couple extra tires to get me to 6k.
It’s so cringe to see randos explaining their overly simplified takes on tax code.
KyleQ
Kyle
Twin Cities, MN
8 Broncos!
My EB came in at 5200lbs with a 5.8/C4/AtlasII on 60/10.25 H1's and 43's.
Makes me wonder what the 4 door Badlands Lux SAS is going to come in at...
Ford Bronco Stopped by the scale yesterday. Bronco Gilbert20
jaruss01
NJ
Badlands has a couple hundred pounds between the front and rear steel bumpers and bashplates.
My loaded OBX sas 4 door (MIC lux 2.7) is basically the same weight as your two door. 5017 lbs / 1,083 payload / 6,100 GVWR. Although I intentionally forego'ed the steel stuff to get it down to 5,000. Not horrendous for a 4 door with 35s.
LarryZiegler
Larry
It depends on the trim as to the GVW. My OBX 4 DR 2.7 non Squatch has the 6100 lb GVWR sticker in the door jamb, thus qualifying as a truck for tax purposes and the cargo weight carrying capacity rating is just under 1,300 lbs.
dbeyers
Dan
Denver
Toyota Highlander
GToddC5
Todd
South Jersey
www.bronco6g.com
Good thing when I bought my QuickJack in 2020, I got the 7000lb. capacity!
CT203
Connecticut
'13 JK
Put my Bronco on the scale yesterday. It was reading 140 kg empty so subtracting that from the 2400 kg displayed makes it 2260 kg or 4982 lbs. That’s with half a tank of gas and no cargo of any kind. That’s about 200 lbs heavier than my 4 door Explorer including the winch. I am not really surprised though, modern vehicles are so heavy.
Specs: 2021 Bronco 2dr Badlands, Rapid Red, 2.7L, Sasquatch, Lux, Leather, Towing
OP was sitting in it? :p
jwmach1
James
St. Louis, MO
2021 Badlands, 2013 Wrangler, 2006 Wrangler
She carries it well.
CMillBronco
Craig
2024 GMC HD 3500 AT4, 2022 Toyota Tacoma TRDORP, 2023 4Runner TRDORP
Awesome thanks I've been waiting on a 2 door weight, I'm going to be flat towing mine so need to make sure the towing equipement is 5k+.
Now if you want to talk fatty my 21' GMC 3500 weighs 8356 pds!
