CAT scale weight measurements ...
twvette
Todd
AZ
If this helps someone my '26 four door, 2.3L, automatic, painted hard top, sasquach package, black diamond package, non-Lux package, no trailer hitch, capable bumpers that is essentially off the showroom floor (no aftermarket stuff (yet!) weighed 2,700lbs front and 2,260lbs rear (4,960lbs total). I almost certain this was without me sitting in it when weighed and I was a little over 1/4 tank on gas remaining. Using this as starting point for some custom aftermarket shock tuning/suspension getting done. The internet/AI weights are all over the place (lots of variables) so wanted to verify mine.
Techun
Pa
BD, 2.7, MIC, 4dr
Sounds right. My 4dr BD V6 should be like 4,997 IIRC
Mike leggiero
Ky
close cat scale weight a little heavy.
Gopher
Stroppe
Kyle
69 Mach I, 70 BOSS 302, 17 Shelby GT350
Stroppe
I visited my local waste station (aka the dump), which has a scale where you check in. My 2-door Stroppe holding me, 1/2 tank of gas, fishing gear, and some garbage weighed 5,260 lbs. More than I expected.
Ford Bronco CAT scale weight measurements ... PXL_20260703_165203454
1994 Bronco XLT - 2024 Badlands 4dr 2.7 SAS
Had my 24' Badlands SAS on the scale today. 5580 lbs. (adjusted for my weight removed). 2.7, High/LUX, mod. bumper with Ford winch package, 75 ish lbs. of recovery gear, alum. trans skid, full tank, stock tires/wheels, and a bunch of small insignificant stuff. About what I was expecting. Guess I shouldn't be too disappointed with 16 mpg.
