Squatchn'
Palm Harbor, FL
2021 BaseSquatch, 2021 Explorer XLT
Thanks for the post. So how is the stinger performing. I’ve seen reviews that talk about to dying quickly . I like the looks of the box but sound and quality matter more in the end.
also a little worried about a speaker facing into the cabin area . I feel like there needs to be grille over the speaker to protect it.
The stinger sub is great. It provides really deep, tight bass with no slop at all. It has plenty of power as well. I can't speak to the longevity of it because I haven't had it that long, but no issues to date. Also, it comes with a grille so you don't have to worry about stuff in the trunk ruining the speaker.
stickshifthappy
RVA
Ford Ranger, 65 Mustang
I installed the same stringer sub, but used their phoenix gold 500.1 amp to power it, I've replaced all the other speakers (kicker and focal).. I am not super happy with the balance though... I've got the bass gain knob turned all the way down, but the bass is too 'boomy' compared to the rest of the system, which makes sense when you think about the fact that the rest of the system is made of of 5 4" speakers and two 6.5's, and then it goes to the 12" with nothing in between. I wish this box had an 8" or maybe 10" woofer in it, I think it would have provided a more balanced sound
That's my issue as well. I don't think I want a 12” sub a 10” should be plenty. My tree guy has been saying g because it's an open air vehicle I need the extra sub. I've been driving a 65 mustang convertible and haven't missed bass in the open top driving (smaller cabin sure, but 12" is pretty damn big). I don't wanna pull up to people, and rattle their glass cause I've got my volume cranked a bit.
Silence
SD
2022 Bronco
Just get a remote bass knob and install up front. can always use that to turn down the bass easily if needed.
stickshifthappy
RVA
Thanks I had that very conversation with my stereo guy this morning going with the stinger 12 inch door mounted subwoofer and they’ll be a control so I can turn down the base as needed
fallguy
fallguy
Tennessee
2020 Defender, 2022 Outerbanks SAS, 1968 Mustang
I agree with all of this. Bass sounds good, and you can turn it down too. Really, really happy with the results with everything I did.
JCR got back to me, I am about 3 weeks out from them shipping the shelf. Will post a pic after.
IndefiniteJay
Joe
Missouri
Ford Bronco
I had actually been looking into installing a sub on my tailgate as well but I was worried it would be an issue if I also got a security enclosure in the back. I noticed you had the MOLLE panels as the walls which probably aids in not ruining the sound. I’m afraid if I get the Diabolical security enclosure, the sub would be playing into an all metal wall enclosure and it would ruin the sound. Any suggestions?
I also did not stop to think that the enclosure wouldn’t fit flush with the sub in the way so that’s another thing to take into consideration.
fallguy
fallguy
Tennessee
You are probably right, it'd bounce off the plastic wall. Because the parts that were touching the plastic towards the top did just that. Not after I lined them with rubber door guards. I lose a bit of space with the molle not being all the way to the side wall, but the molle allows me to hang things and I think it's worth it. The extra storage from the shelf should help. Molle adds some airflow too, we'll be keeping my son's iPad and such back there when out and about. A total enclosure with next to no airflow will probably bake the iPad.
I msg Diabolical on these forums asking for measurements to see if the sub enclosure would fit without modification, they never responded so kept the Ford one and just cut it. Really wasn't that bad. I made a post about installing it with some pics if you haven't seen it.
Actually just got notification that the Jcr shelf shipped. I'll update a pic when it's here.
IndefiniteJay
Joe
Missouri
Ford Bronco
I had not thought about an additional shelf on top of the enclosure. If it’s easy to put on and off, then I’ll consider it.
It makes sense that the MOLLE panels on the enclosure would probably be a better choice to pair with the sub. I’m also not one to carry long or tall items to be limited by the Fords enclosure walls so I guess it’s a win win.
I’m not sure if I might have missed it but if you find a solution for the sub bumping into the security enclosure, please let me know.
fallguy
fallguy
Tennessee
Ford Bronco Stinger tailgate sub installed, Stinger 700w amp install under driver seat with pics, 6.5 Mabett rear Kickers 20230328_144359
Ford Bronco Stinger tailgate sub installed, Stinger 700w amp install under driver seat with pics, 6.5 Mabett rear Kickers 20230328_144312
I just used a jigsaw to cut around the sub. Took some measurements and marked it off. Didn't take very long, and pretty tight fitting. Originally the top of the enclosure went straight across. I lost a tie down, but otherwise is about the same. Still secured by the same 4 screws, that are only accessed from the inside. The top shelf attaches by the bolts that hold the hard top on, so will be easy to remove if necessary. I have 3rd party one that can be removed by hand.
fallguy
fallguy
Tennessee
Shelf came in yesterday, installed today. Fits perfectly, little extra storage space. Going to get a 5x3' cargo net to secure things down with. Lots of places to hook a carabiner, even extra screws that fit in some holes in the event you want to bolt something down. Really happy with it.
Was worried about the 6.5" pods in the rear not working, but just enough room.
Ford Bronco Stinger tailgate sub installed, Stinger 700w amp install under driver seat with pics, 6.5 Mabett rear Kickers 20230419_151539
Ford Bronco Stinger tailgate sub installed, Stinger 700w amp install under driver seat with pics, 6.5 Mabett rear Kickers 20230419_151549
Ford Bronco Stinger tailgate sub installed, Stinger 700w amp install under driver seat with pics, 6.5 Mabett rear Kickers 20230419_150211
Whodat
New Orleans
Jeep Wrangler Rubicon
For someone that only added the stinger sub and made no other changes, was that adequate? This base audio system with no sub is terrible. LIke a tin can. Thanks.
Golfsnob
St Augustine
2023 Base 2 Door, Manual, 2.3
What shelf is that? I have the JCR Offroad one on the way.
fallguy
fallguy
Tennessee
I replaced all 6 stock speakers with kickers first, and then the two back 4" with 6.5" with the 200.4 kicker key. So I had pretty decent audio before the sub. The sub was such an improvement, more of an improvement than the other upgrades I did first though in my opinion. Tough choice, but the sub was probably the more impactful upgrade. With the top off though the extra volume from the other speakers is pretty obvious. Upgrading the front two speakers was the most improvement.
I have two 4" kicker speakers with bass blockers on them I had in the back, that I took out and put 6.5's in. Plus a few extra speaker connectors, ordered extra on accident when I upgraded speakers. You are welcome to them if you want them, help out a little bit to better sound.
That is the JCR. They make two shelves though, this one and one that is higher. Which did you get?
Golfsnob
St Augustine
I purchased the same (lower) and also have the tailgate table on the way. Shelf should be here Tuesday.
