steering wheel wrap
flip
Phil
IN
www.ruxerparts.com
Fords
I'm looking for a direct replacement leather with none of the nonsense like lane assist, etc. Anyone know the part number? @flip ?
M2DZ-3600-BB Wheel only, no switches, no trim ring, no heat, no lane keeping.
Brokenparts
Zach
Hillsboro, OR
1966 FJ45, 73 c-10, 79 Blazer, '23 Exp, 2008 F350,
I used tennis racket wrap for my f350 steering wheel when it started to unravel. Worked perfect.
67BroncoG1
Ron
CA
'22 2D Squatch, '67 Bronco, '24 Grenadier -ordered
@flip is this a direct replacement? Disconnect the battery, transfer airbag, switches, and trim ring over? Is there a special tool or will a standard puller work?
I have 62,000 ford pass points burning a hole in my app and this might just be worth spending them on.
flip
Phil
IN
www.ruxerparts.com
Fords
Have not done one but we've sold a couple and none have been returned. Should be GTG.
Steering Wheel
Removal
NOTE:
Removal steps in this procedure may contain installation details.
NOTE: Make sure the steering wheel and the road wheels are in the straight ahead position.
NOTE: Heated steering wheel shown, others similar.
  1. Remove the driver airbag.
    Refer to: Driver Airbag (501-20B Supplemental Restraint System, Removal and Installation).
  1. Disconnect the steering wheel electrical connector(s).
  1. NOTE: Make sure the tick-mark on the end of the steering column shaft is on the top position.
    Remove and discard the steering wheel bolt and remove the steering wheel.
    Torque: 46 lb.ft (62.5 Nm)
  1. Tape the clockspring rotor to the outer housing to keep it from rotating.
Installation
  1. To install, reverse the removal procedure.
TacosTuesday
Carlsbad, CA
'23 Badlands 2dr 2.7L
i HATED the feel of the stock wheel, so i did what i've done in my last 6 cars, gone custom. easier to keep clean, looks amazing, feels amazing. it came with a CF trim piece, but i always use the stock one. makes it look almost factory
Ford Bronco steering wheel wrap 1700081652629
67BroncoG1
Ron
CA
cool steering wheel. who did the work and what did that cost?
67BroncoG1
Ron
CA
Steering Wheel
Removal
NOTE:
  2. Disconnect the steering wheel electrical connector(s).
Installation
@flip Thank you for the quick reply and posting the instruction. Last question, how does the airbag release? I would imagine there is something on the back side of the wheel that you have to push in or unscrew.
Thank you for the help.
flip
Phil
IN
www.ruxerparts.com
Fords
Dang, forgot to include that.
Driver Airbag
Removal
  1. Ford Bronco {thread} {filename}
    WARNING: The following procedure prescribes critical repair steps required for correct restraint system operation during a crash. Follow all notes and steps carefully. Failure to follow step instructions may result in incorrect operation of the restraint system and increases the risk of serious personal injury or death in a crash.
    Refer to: Pyrotechnic Device Health and Safety Precautions (100-00 General Information, Description and Operation).
  1. Depower the SRS .
    Refer to: Supplemental Restraint System (SRS) Depowering (501-20B Supplemental Restraint System, General Procedures).
  1. NOTE: To prevent binding, both of the driver airbag retainers should be released at the same time.
    On both sides.
    At the side of the steering wheel cover, locate the hole and insert a 3 mm (0.125 inch) hex key.
  1. NOTE: The driver airbag has been removed for clarity.
    Contact the hex key to the spring clip.
  1. On both sides, at the same time.
    Push in on the steering wheel spring clip to release the driver airbag retainer.
  1. Position the driver airbag down and release it from the steering wheel spring clip.
  1. Disconnect the electrical connectors and remove the driver airbag.
Installation
  1. Connect the driver airbag electrical connectors.
  1. Align the driver airbag to the steering wheel and push in, engaging the driver airbag retainers to the spring clips.
  1. Repower the SRS
    Refer to: Supplemental Restraint System (SRS) Repowering (501-20B Supplemental Restraint System, General Procedures).
flip
Phil
IN
www.ruxerparts.com
Fords
Driver Airbag
Removal
  2. Depower the SRS .
  3. NOTE: To prevent binding, both of the driver airbag retainers should be released at the same time.
    On both sides.
Installation
  1. Repower the SRS
TacosTuesday
Carlsbad, CA
i got this one from carbontastic, was $1500, no core required. they got a bunch of options, type of carbon and the finish, what material you want and where for the leather areas, stitching colors, 12 o'clock strip color and design, etc...
a few weeks after i placed my order, i saw that archetype racing started selling carbon wheels too, for about half what i paid, but core exchange needed. only a few options for customization though, but hard to argue with the price difference.
BroncoBoy22
Laker Land
'11 Mustang GT 5.0
Where’d you buy that from?
67BroncoG1
Ron
CA
it is beautiful but too rich for my blood.
67BroncoG1
Ron
CA
Driver Airbag
Removal
    On both sides.
Installation
  1. Repower the SRS
thank you! I’m guessing that disconnecting the battery will make the airbag safe To remove.
67BroncoG1
Ron
CA
Driver Airbag
Removal
    On both sides.
Installation
  1. Repower the SRS
