Steering wheel very sensitive after off-roading
Your alignment is off. Get it checked out. The LCA alignment bolts are just sandwiched, so they can move with a good jolt.
its also possible you bent a tie rod enough to throw off the toe.
You win the pool
LSW
LSW
L
North
'24 Bronco Wildtrak
Tie rods: looks like just the driver side is bent?
Driver
Ford Bronco Steering wheel very sensitive after off-roading IMG_3305
passenger
Ford Bronco Steering wheel very sensitive after off-roading IMG_3306
cbrownabq
Littleton, CO
Dodge 2500 diesel
BDS alignment locks are the bomb for this. No more alignment woes.
Driver
passenger
Those like exactly like mine - if there’s a bend I don’t see it, but it may just be the photo.
My driver:
Ford Bronco Steering wheel very sensitive after off-roading imag
  • Like
Reactions: LSW
Tricky Mike
21 Bronco
Is the bend on the other plane - visible from looking at it top down?
If you're going to be doing a lot of off-roading, it might make sense to see if you have a Firestone near you that has an unlimited alignment deal.
It's an amazing deal for stock vehicles. Back in the day they would even cover lifted vehicles but that must have bit them in the ass.
LSW
LSW
L
North
'24 Bronco Wildtrak
Not sure but this what they looked like from above. Look pretty close to the same?
Ford Bronco Steering wheel very sensitive after off-roading IMG_3312
Ford Bronco Steering wheel very sensitive after off-roading IMG_3314
LSW
LSW
L
North
'24 Bronco Wildtrak
I got the work done. Dealer replaced driver's side tie-rod end and performed a front-end alignment. The repair didn't really seem to make a difference in the steering though; Maaaaybe a 5% difference but it still feels a litle looser than before. Oh well, they said it was good to go and felt normal to them.
I didn’t see this until today after you had the work done but — yeah mine look identical from top too. Although your driver one did look a lil more bent than the passenger - mine are about the same - so maybe that’s what they saw.
But it’s done - hopefully they gave you the old parts so you have a spare to carry
