Steering rack bolt torque specs
Rush4th
Donny
Norco, ca
2021 bronco
Did the broncbuster stuff. Anyone have the torque specs?
Ducati1098
Which specs do you specifically need? I’m not sure what all you removed.
The rack mounting bolts themselves are 184 lb.ft
Rush4th
Donny
Norco, ca
2021 bronco
that's what I needed! How about tie rod end bolts? Thanks!.
zuke
Stafford VA
46 ft/lb, the column coupler is 22 ft/lb if you need that too...
mpeugeot
Saved me time looking it up. Thanks!
Rush4th
Donny
Norco, ca
2021 bronco
I appreciate the help everybody!
