Stealthbox for Bronco
da_jokker
Jeep Wrangler JKUR
So I take it this is not one of those self contained and amped subs? Just a box with a speaker and It's up to you to power it?
Saturnalp
Erin
Polk City,FL
2006 Saturn Vue
Correct, you’ll need to connect an amplifier to it. We currently have a JL Audio VX700/5i powering it. It is mounted under the passenger front seat.
Ford Bronco Stealthbox for Bronco 5359C06C-0271-4F50-8A41-45F75DA37D05
da_jokker
Jeep Wrangler JKUR
Ah.. duh... I don't know why but for some reason I thought it mounted to the seat itself but now I see it's basically on the floor underneath. And yeah I do see that there is a few inches of clearance coming from the back before it starts to hit the unlevel floor and all the junk.
Doobie
Will
TX
Ram 1500
Anyone have an idea on the specs? I found this one from SRQ Customs that has an 8” kicker but sounds like it isn’t a whole lot of base.
https://srqcustoms.com/product/ford-bronco-subwoofer-enclosure-with-grille/
Also something to consider is the square 8 is going to have more surface area than a normal round 8. if all things are equal, then you will have more air moving with the same amount power. Its a very good upgrade and likely will cost much less than the JL with a 10 shallow mount, not sure of the series they are using, but they are pricey.
Bird Dog Off Road
Jody
Phoenix, AZ
www.youtube.com
So, is this thing mounting in the same area as the factory sub or under the passenger seat? I'm confused.
Silence
SD
2022 Bronco
Those are amplifiers, which you can mount in multiple locations depending upon size and application. The jl stealth box mounts in existing sub location area.
KompressorV12
Portland, Oregon
19' Jeep Grand Cherokee High Altitude
The Stealthbox is coming, don’t know when. It is a 10T1W2 View attachment 484561
There should be no reason I can't keep the factory amp for my speakers and just use a separate smaller subwoofer amp like a kicker 500.1 key for sub right? Hopefully it's just the subwoofer and box JL will sell and not some package. Under seat is a big no no for me. But I love this box. Really curious what they do to the plastic cover.
sLopeFx
FxA
Los Angeles, CA
22 Bronco BD Sas, 07 BMW 335i, 02 Cooper S JCW
So it sounds like the stealth box will only be for a shallow mount 10"? Can you please confirm? If so, that's a huge bummer..
Silence
SD
2022 Bronco
that's correct. what were you expecting to fit in that location out of curiosity?
Sandbergo
Jelani & Dave
Orlando
Rogue
It’s definitely a 10TW1 in the stealth box, the guy at JL Audio confirmed it, said they were test fitting last month and final approval last month as of March 15th. Said they were waiting for the production molds to be finished before they could begin production. As for the size of the woofer, I have a 12tw3 that I planned on putting in but the diameter is just a bit too large to hide it without any modifications to the panel. From my experience with stealth boxes they are mostly hidden away and sound great.
Karl_in_Chicago
Karl
Chicago
I bought this while waiting for my Bronco from Ford . . . are you saying it's not gonna fit? Will the stock head unit have enough power or will the speaker cables be the limiting factor? I really don't want to have to send it back, the shipping charges were killer!
Ford Bronco Stealthbox for Bronco giant-subwoofer-picture
Tye
Tye
San Francisco
Porsche GT3, Landrover Defender V8, BMW X3 Msport
So basically we will see it released in Q3 or Q4 this year, lol. FWIW, I was told it was test fitting and final approval back in December 2022.
Sandbergo
Jelani & Dave
Orlando
Rogue
Yeah I was told they did that for the four door then and last month they had a two door in. Eric Cole is the guy I’ve been corresponding with at JL, he ended his last email with that it could be a bit still before they are released.
