SSV 6" speakers
Dan-O
Dan
Fountain Hills, AZ
I have the Mabett pods on 2dr and they do not interfere with the seat belt. However, the metal bushing that comes with Mabetts is too long for the bottom bolt to reach threads in roll bar. If the bushings aren’t used the pods will interfere with seat belt. I trimmed about 3/8” or so off of the bushing and the gap from top to bottom is equal. But no problems with seat belt for my 2 dr
Sorry I may have given you some bad info. I checked the set belt interference again. Seat belt plastic cover on top mount does not interfere but If I sit in rear seat and put seatbelt on the plastic cover on upper belt mount does make contact with side of pod ever so lightly. I don’t see it as an issue though.
Portapot
Maryland
Cj7, RX350, f250,
Put 6.5" in the rear, sounds a lot better with the EQ settings changed but I still can't turn them up very loud without distortion or feeling like I may blow them out. I feel like I may need to put bass blockers on them. no Sub, 2 Door, non B&O. Has anyone else added bass blockers? Any suggestions?
