- Mikhail
- Dec 28, 2022
- 3
- 49
- 22
- Vancouver, WA USA
- Ford Bronco
- Outer Banks
- #16
Not yet. I was asked to bring it in.
This isn’t normal by any means…What you’re describing sounds like Binding which is normal in AWD cars. It happens at very slow speeds on pavement while fully turning the wheel.
interested to hear the diagnosis. I was responding to the OP who said the issue was only going slow speeds in parking lot in 4A while fully turning steering wheel. This sounds like classic AWD binding and it’s normal. I will see if I can replicate on mine.This isn’t normal by any means…
I am having the same exact issue. I already took mine (2/14/23) and I have yet to hear what is wrong. The service manager told me they were leaning towards replacing the transfer case. Hopefully I have an answer tomorrow.
Binding at low speeds in 4A is not normal. There should be no power distribution to the front wheels at low speeds or while turning in a parking lot.interested to hear the diagnosis. I was responding to the OP who said the issue was only going slow speeds in parking lot in 4A while fully turning steering wheel. This sounds like classic AWD binding and it’s normal. I will see if I can replicate on mine.
Hello. I can look into your Bronco’s concerns on my end. Will you send us a private message with your VIN and dealership info?Following as I have the same issue.
Any updates with this?
When the issue first manifested I had driven to a store in Sport mode which by default it changes from 2H to 4A and from previous times (4 months of use) its always behaved the same way. (I go around a roundabout leaving and entering my community and it never had an issue in 4A) Well this time, when I turned on the Bronco and it asked me to stay in Sport mode which I did and when I backed out of my parking spot it felt like my rear mudflap was loose and rubbing on the rear right tire. I got out and checked to make sure it wasnt a mudflap or something that was lodged rubbing against the tire. Luckily the parking lot was nearly empty so I was able to drive it in a circle and figure 8 to listen and feel for binding, noise and if there was anything rubbing. After a few minutes of going through the modes (EXCEPT FOR 4L and 4H) I found that it only did it in 4A.interested to hear the diagnosis. I was responding to the OP who said the issue was only going slow speeds in parking lot in 4A while fully turning steering wheel. This sounds like classic AWD binding and it’s normal. I will see if I can replicate on mine.
I drove to work in 2H like normal and everything was fine. I later tested 4H and 4L in more of an off road environment and it didn't bind.
Its still at the dealer today (day 5) and they still don't know what is wrong. Last I heard they were removing the front drive shaft to see if its the joints but I really doubt that is it.
Yes, but they were very adamant about putting me in a loaner / rental until they had a repair scheduled and parts available.Are they giving you a loaner to drive?
In my understanding of that system, there should be lines striped on the road, which were absent on the parking lot, therefore I DO NOT think it was the lane departure system.Maybe an obvious question, Are you sure its not the Lane Departure notification?
I though mine was doing this than I noticed the red indicator on the dash cluster
It is definitely not lane departure.Maybe an obvious question, Are you sure its not the Lane Departure notification?
A torque-on-demand transfer case is not a classic AWD system with a viscous or mechanical center differential, it's not a Subaru. The TC has the ability to 100% uncouple the front and rear axles. In theory, it should do this in 4A at high steering wheel angle with no slippage detected.This sounds like classic AWD binding and it’s normal. I will see if I can replicate on mine.
There should absolutely be power distribution to the front wheels at slow speeds. Someone needs to pull up Forscan at watch the TCCM command to the TC in 4A. It sends power to the front wheels any time the accelerator is applied from a stop, even without any slippage detected. It tapers the clutch out the more you turn the wheel, but the default is absolutely to send power to the front at slow speeds.Binding at low speeds in 4A is not normal. There should be no power distribution to the front wheels at low speeds or while turning in a parking lot.
