Spare tire rubber bumpers
Status
Not open for further replies.
Gtrekker
Gary
Can you expound? My light clears ok.
Expound? Hmmmm....
I have 37" KO2s. They fit on the spare tires 3rd brake light but, this light is close to the top of the tire. I added a bumper to resolve that. See earlier in my posts.
Tricky Dick
Dick
PNW
www.TD-Distributing.com
Expound? Hmmmm....
Oh I see. I'm talking about the bumpers at the bottom of the tire. I have good clearance around the light/bracket.
campbebc
Ben
Waterford, VA
2021 Ford Bronco, 2019 F-150 Raptor, 2004 Mazdaspeed MX-5
Get a PVC pipe cap that will shove in the end, paint it black
Gtrekker
Gary
There was another post of installing a wheel spacer on the tire carrier to allow more room.
Tricky Dick
Dick
PNW
Tricky Dick
Dick
PNW
Finally got my spare on. These things are massive. Much thicker and longer, and harder too. *snicker*
Had to trim the nipple off and drill out to use the oem fasteners. Then trimmed the excess length off at an angle to fit the shape of the tire better.
Ford Bronco Spare tire rubber bumpers 20220302_175215
Ford Bronco Spare tire rubber bumpers Screenshot_20220302-175807
1979
Ben
Baltimore, MD
2023 Bronco Raptor
Thank you for this. Followed your lead and did this today. Worked out perfectly.
straycat
St. Louis, MO
2011 Toyota Camry, 2021 Ford Bronco
Is this something I will need to anticipate being an issue as well? I just upgraded to 35's, and will be installing a relocation kit this weekend.
Also....this gave me a chuckle
Ford Bronco Spare tire rubber bumpers Screenshot 2022-04-14 4.28.31 PM
Tricky Dick
Dick
PNW
AKA the pursuit of happiness.
FlyingScot
Tomball, TX
2022 Wildtrak 4dr
Thank y'all for doing the legwork on this one. Tentatively planning on going from the 315/70r17s to 35x11.5 Toyo AT3s as soon as I can rationalize ditching the goodyears, I'd hoped it would be a small enough width change to not need to mess with this, but good to know there are proper solutions in the event I'm wrong!
30snack
2018 F150
These just plugged right into the tailgate just like the stock ones?
Tricky Dick
Dick
PNW
They have a nipple on them that's supposed to plug in but it's too big. I shaved it off, drilled a hole, and used the original fasteners.
BigBendBW
Columbus, Ohio
Bronco Base Sasquatch
That sounds about right, I went the other way. I went from an Outer Banks spare to a Badlands spare and calculated I needed the cut 7/16 off of those (Outer Banks) bumpers for the Badlands tire to fit.
Was that the right amount? I’m moving from the black steelies on my BD to 33” tires and want to make sure I trim the right amount.
Status
