Spare tire rubber bumpers
Status
Not open for further replies.
Beachin 74
Delaware
Was that the right amount? I’m moving from the black steelies on my BD to 33” tires and want to make sure I trim the right amount.
I can't say for sure because I don't know what width of 33" tire you are going to use or the width or off-set of the new rim.
To be sure, put a straight edge across the back of the original tire/rim and measure from the straight edge to the wheel's bolting flange surface. Do the same to the new tire/rim and whatever the difference is between the 2 measurements is what you will need to remove or add (depending on width/off-set) from the rubber bumper.
BigBendBW
Columbus, Ohio
Bronco Base Sasquatch
Thank you! Same offset as factory and tires is a little more than 3/4” wider than previous. Great advice on how to confirm, really appreciate it.
crimsonhokie
Knoxville
'07 Civic Si, '17 Ducati Supersport S
I need a bumper about 1/2" taller. I was thinking about putting a spacer behind mine but they're only held on with those cheesy push clips and it's not long enough for both. Maybe base bumpers are longer?
How did you get the fasteners off? I've unscrewed and ensured the fastener's still saying in place, but the screw doesn't back out at all.
Tricky Dick
Dick
PNW
www.TD-Distributing.com
You have turn without putting any pressure and hope they don't strip. If that doesn't work a small pick can get them out.
crimsonhokie
Knoxville
I ended up cutting them off with a dremel :oops:. Now I've gotta get a couple replacements.
broncorik
Rob
Ford makes two lengths...the shorter one comes on SAS. I had to buy the other when I went with a different tailgate support plate.
swooshdave
Portland, Oregon
Mustang
@flip You wouldn’t happen to have the two part numbers for the long and short bump stops for the spare tires?
Does anyone have the length of the longer ones?
flip
Phil
IN
www.ruxerparts.com
Fords
swooshdave
Portland, Oregon
Mustang
M2DZ-1A401-A 50mm (1.97in)
M2DZ-1A401-B 33mm (1.28in)
M2DZ-1A401-C 42mm (1.64in)
Of course I need the A which is out of stock. It will still let me order and gives a shipping date estimate. I assume that means that Ruxer will pull from Ford warehouse and ship?
flip
Phil
IN
www.ruxerparts.com
Fords
Yes. You can get where ever, I was just too lazy to pull up each pic to get measurements. Don't want anyone to think I was promoting our store.
swooshdave
Portland, Oregon
Mustang
Yes, but you have the juicy delicious pricing. And by far the least expensive shipping.
flip
Phil
IN
www.ruxerparts.com
Fords
Makes me feel like a filthy whore sometimes when I like to the store to show a pic or details of something. I had to manually add a lot of the bronco stuff to the store since the catalogue (Motors) that Revolution uses has horrible pics and is about 1 year behind. Just easier to post the link than try to find a note I may have buried on my desk.
swooshdave
Portland, Oregon
Mustang
You are doing the Lord's work for us poor Bronco owners. :)
Status
