Someone please explain how the wheels work?
Targgus
Denver, CO
You're stripping them because you might have the wrong tools. The screws are Torx-Plus, using a regular Torx will strip if overtightened. I don't know the torque speq on them, but they should be properly torqued to prevent over-tightening and damaging the inside threads. The right tools will always help get it done right.
1) I stripped it while unthreading, not tightening.
2) There's tons of threads saying Torx and tons saying Torx Plus. The T45 fit snug for me.
If you can prove me wrong with your Bronco wheels, I'll go buy a Torx-Plus bit right now.
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
Cat
Cat
Whidbey Island, WA
MB500SL, HD Road King Custom
Alright guys im not clear on how the 17" Black High-Gloss Painted Aluminum with Warm Alloy Beauty Ring, Beadlock Capable Wheels work. what does it mean beadlock capable? is it possible to make it true beadlock and if so what does it intel? if i take it to a tireshop and say i want to make it beadlock will they look at me like im an idiot? is it predrilled? does the ring need to be replaced and if so from where. This might be a simple to most but its not clear to me
Great question!
Learned something today!
Lexo52
Arlexis
Ford F150
So how likely is someone to get pulled over for having beadlocks? And is it unsafe driving with beadlocks? Only ask because the racecar guys out here run beadlocks around and my buddy says when he gets pulled over it is usually because of the slicks not the beadlock rim
wanna1
Andrew
2013 Ford F150 Platinum 4x4 2022 Mach E
I'm planning on Icon Rebound Pros.
Deano Bronc
Dean
Winona Lake, IN
2022 Badlands
I found these pictures awhile back and seems to show the difference pretty well.
Ford Bronco Someone please explain how the wheels work? Sasquatch Rim cutaway
Ford Bronco Someone please explain how the wheels work? Bead lock rim cutaway
iamcris
Cristian
Lakewood, WA
21 Bronco Badlands
https://www.amazon.com/Lisle-81000-...keywords=torx+plus&qid=1645160357&s=hi&sr=1-6
I would trust this Lisle set before any Chinese knock off. If you're not buying Snap-On, Mac, Matco, OTC or Cornwell get the Lisle set. Lisle has amazing customer service and make quality tools. The difference between a Torx and a Torx plus is the Torx plus have a flat edge whereas the regular Torx are rounded. I'll see if I can post a picture. It's very easy to see the difference on the fastener below...
https://www.sloky.com.tw/Templates/pic/accessaries_bits02.jpg
One other trick you can try if it's ugga dugga tight is before trying to loosen the fastener smack the top of the ratchet (socket attached and in the fastener) with a hammer the vibration often times helps break the seal. Also, let me know if the factory used loctite on the threads (usually blue paint on the threads).
