- First Name
- Eric
- Joined
- Jul 10, 2021
- Threads
- 71
- Messages
- 2,106
- Reaction score
- 8,295
- Location
- Sacramento, California
- Vehicle(s)
- 2017 Raptor
- Your Bronco Model
- Wildtrak
Sign me up it just what I need, NOT!!!
First rule of full hydro club is you don't talk about full hydroIsn't hydro-steering not DOT approved and off-road only?
The DOT doesnt make laws.Isn't hydro-steering not DOT approved and off-road only?
RegulationsThe DOT doesnt make laws.
I disagree. The Panhard is short but its position will severly limit travel. Limited travel equals limited chance of bump steer. It only has a couple of inches of up travel on the driver's side. I wonder how they have the bumps set to keep it out of the oil pan and the axle side mount out of the frame. The majority of the articulation is coming from the rear in those shots.Two things:
That panhard bar on the front looks super short so there will be a lot of lateral axle movement through the travel. It's probably a good thing they did hydro steer or else bump steer would have been unavoidable.
Bigger problem is the trackbar goes driver down toward passenger on both the front and the rear. That is a big tip over no-no. Maybe they relocated the rear but I do not see any images of it.Two things:
The rest of the suspension links sure hang down low everywhere.
The future is now, old man!Wish Bronco came from the factory like this.
Many here will disagree, but not I.
