- Joined
- Mar 14, 2020
- Threads
- 9
- Messages
- 1,309
- Reaction score
- 2,238
- Location
- Upstate NY
- Vehicle(s)
- 2015 Mustang GT - 2022 Bronco Wildtrak
- Your Bronco Model
- Wildtrak
Do tell.already have an appointment with the dealership for other reasons.
I was about to ask the same. It appears curled like someone deliberately forced it open.Any evidence of a break in attempt? Other than that you’re doing the right thing. They should fix it under warranty
Problems with the other, even less durable, removable top option? Never would have guessed that would happen ...Has anyone had an issue with their soft top rear window pulling...
But don't the ones pulled by Ford for quality checks come with a statement that says it was done and documents the number of miles? If you didn't get that, then the sales manager (or other manger) got to take your Bronco for a cruise or two.As a ford dealership technician i can say it’s not uncommon for there to be what some would consider excessive miles. Occasional ford will randomly select vehicles after being built for an extensive quality control test of things like the suspension. Also with all the delays and that flooding Detroit had a while back they probably got moved from storage lot to other lots.
That was my first thought too. The thing is, if someone wanted to they could very easily continue the separation. All someone would have to do is pull on that curled up corner and it seems the whole damn window could come off.Any evidence of a break in attempt? Other than that you’re doing the right thing. They should fix it under warranty
Do tell.
1. Deep scratch on both side of the roll bar from the top mechanism found on day 1.Do tell.
If that is how it came, it's not how it should be and Ford should fix it under warranty, IMOGreat question! I pressed the dealership for an answer and got zero information. They say that's how it came. I've heard of folks taking delivery with around 40 miles but nothing like 100. It was actually 108.
Here’s my slip. Was in the glove box.But don't the ones pulled by Ford for quality checks come with a statement that says it was done and documents the number of miles?
I just drove mine with top down at hiway speeds. Put heavy force on rear panel I would recommend it especially if very hot. If I drive with top down I will remove side and rear panels. As a side not don't go thru mud puddles at even 10 mph. With top down you will regret itNo issues yet with mine and I have driven hours at 70-80mph with the top down and the wind hitting the back window. Hopefully that is not a common occurrence
