Soft Top - Rear Panel Separated from Plastic Corner
Fourd
Fourd
ROA
2009 Volvo V8 X90R
So the leftmost edge of rear panel detached from the plastic corner piece. See photos. Any idea how it was attached or adhered? Any suggestions for how to fix? Thanks in advance.
Ford Bronco Soft Top - Rear Panel Separated from Plastic Corner IMG_7598
Ford Bronco Soft Top - Rear Panel Separated from Plastic Corner IMG_7597
Ford Bronco Soft Top - Rear Panel Separated from Plastic Corner IMG_7596
Area51BS
Ron
Badlands non SAS 4dr 2.3
Appears yours is held by clips that broke off. Ford placed rivets(TSB)right where the clips would go. I can get you a pic tonight. Easy fix
Area51BS
Ron
All 3 locations. Might be 4 but you get the idea.
Ford Bronco Soft Top - Rear Panel Separated from Plastic Corner IMG_0266
Ford Bronco Soft Top - Rear Panel Separated from Plastic Corner IMG_0269
Ford Bronco Soft Top - Rear Panel Separated from Plastic Corner IMG_0268
desertrat999
2021 bronco
I’ve got this problem too. The dealer is telling me that TSB 22-2055 and TSB 23-2091 are outdated and no longer available. So they want to charge me $2k for a new back window.
Are they being jerks? Should I take it to a local repair guy instead?
Fourd
Fourd
ROA
2009 Volvo V8 X90R
Mine told me same thing and that my problem isn't one covered by TSB, which does not make sense to me. I bought the extended warranty for my Bronco and they certainly did not volunteer it would be covered by it. I don't even want a soft top and only switched to softtop to speed up initial delivery by almost a year (I ordered in early August 2020). In the meanwhile, I am tempted to take the local shop that I trust and is very good, give them the fix sheet posted above and let them "bandaid" fix it however they wish and then just get hard top ordered sooner rather than later.
RobWTX
Would an upholstery shop be able to fix it? I had a different problem with mine, and Ford took it to an upholstery shop to have them fix it. Luckily, it was under warranty at the time.
Headsong
How? Did you try to separate them? Or did it happen without help?
Headsong
Yep, those are not meant to be separated. Ever. You just pop the whole corner off and leave it attached to rear window. Stuff they should tell you early on.
Fourd
Fourd
ROA
2009 Volvo V8 X90R
I am still trying to solve this issue. I did not separate mine. The plastic tabs broke.
I re-read the TSB linked above and that seems exactly on point. Has anyone actually gotten a dealer to follow the TSB and fix in last year?
