Soft top rattle
Jaythor74
Jason
Holland NY
2010 Explorer 2017 F150 2021 Bronco Sport
I’ve had my base since November and been chasing a few rattles on my soft top. I had to unbolt top top on the driver side and push it down to squash the gasket and re-adjust the rear hold down clamp as well. The results are much better but their is still one rattle somewhere around the rear passages door/roll bar area. So far all I can find that could be making the noise is the corner mounding under the roll bar. If you tap on the bottom of the molding it will rattle. Not sure if it’s the cause, anyone have anything else they found? Thanks
‘21OBX
90Bronco19
2022 bronco outer banks
I just picked mine up today and have a rattle type noise from about the same Area you describe. It’s cold and dark so I plan to look at it tomorrow in the work garage. If I find anything I’ll let you know.
Jaythor74
Jason
Holland NY
Ok thanks, I’m in New York and it’s been too cold to play too much. I’m pretty sure on mine it’s the corner molding under the roll bar. There is a round molded spot,if you tap it there is a similar sound. Thanks
WPS-GHG!
West Palm Beach
2019 Ram Rebel, 2021 BD Sas Mid 2.7
With the top down at about 60 the back seatbelts in mine start flapping around and banging on the pillar. I always say I'm going to fasten them so it doesn't happen then I forget.
‘21OBX
90Bronco19
So I flipped my roof back to see what I could find. There is that secondary latch you have to press to fold the top back to the second position. My passenger side was not latched. And when it did it seems a bit loose. But it’s too dang cold up here in MI to investigate. It’s latched now and the noise is better but I’m thinking I need to adjust it so it latches tighter.
Southern Girl
1974 Bronco/2024 Wildtrak
My passenger side sun visor rattles. The squeaks mostly happen when it’s partially open.
