Soft top not clicking/locking when fully retracted
TheKim
Kim
Tried to fully retract the soft top today, but it's not "clicking" or locking into position in the fully reclined/retracted position.
Guessing I just need to put it back up and then back down or something, but is there some kind of trick?
The videos I've watched of others putting the top all the way back, it literally just does it on its own when they throw it back.
Also, going to put that PPF on the roll bar finally, because, it's already scratched the paint in the one time I tried putting it back up to get it to lock properly... yay. Luckily, it's a stupid small chip, and the PPF will stop it from getting worse. Gotta be careful with this stupid thing, the paint is THIN on the Bronco.
Wannabe Techie
Chicago
No trick on mine, just applied pressure and it clicked.
I got nicks and scratches too on my pillar. I got a tip to pull them off and on by going to the 2nd row in the car so you can push/pull from the middle. Seems like a better way since it’s been more balanced. Taking the top completely off is really hard to try to not scratch it though. PPF will def help.
TheKim
TheKim
Kim
I got nicks and scratches too on my pillar. I got a tip to pull them off and on by going to the 2nd row in the car so you can push/pull from the middle. Seems like a better way since it’s been more balanced. Taking the top completely off is really hard to try to nit scratch it though. PPF will def help.
Well, it's currently folded all the way back, so I'll go put the PPF on it and let it sit overnight to "cure" or dry, and then try putting it back up and then back down. Definitely doesn't click or lock into position though... hopefully all I need to do is reset it and try again. If not, guess my dealer will be getting a visit next week, lol.
TheKim
TheKim
Kim
Got it to lock - just pulled that little lever up all the way (guess it could use a little grease), and it popped into place.
We're all good.
22Badskwatch
Sacramento, CA
2022 Badlands Sasquatch
I'm having the same problem .. when it's folded all the way back, it won't latch into place, no matter how much pressure I put on it.
Bonnie6G
Kyle
Denver
Badlands LuxSquatch
Did you ever find a solution to this? I have the same problem.
kevin.gt
Kevin
Canton, GA
My soft top brackets needed adjustments when I took delivery. It had trouble latching and then once latched didn’t want to come unlatched from fully reclined. I think it was the top brackets above the back seats and the ones near the tailgate that I adjusted. There is wiggle room on purpose once you loosen the bracket bolts. Your problem might be different but I’d try adjusting myself before taking it to the dealer
Bonnie6G
Kyle
Denver
Badlands LuxSquatch
Thanks yeah, for me it’s the two small posts in the fully recline position that don’t latch well. The other positions are fine for me. Unfortunately that small bracket only moves side to side, but I need to move it down a bit to get it to engage the latch. I’ve got it to wear I can force engage it with weight down and pulling the gray lever upwards, but it’s definitely not functioning how it should. Maybe my top canvas is folding weird and getting in the way of the bars fully collapsing.
