Soft top installation and adjustments.
jp925
Ventura
2023 Big Bend, 2006 STi, 1974 Bronco
Wondering if anyone has some guidance or insight into properly fitting the soft top onto a hardtop truck. The brackets have so much space for adjustment, and I feel like I’m missing something to get it to sit properly. I had a heck of a time lining up the front latches to close, and now that I did that, my rear window slides don’t line up and the swing gate seal isn’t sealing as tight as it should be; is there a guide or some sort of baseline.
JP2
SoCal
Bronco 4 door
did you ever get it installed and fitted properly?
jp925
jp925
Ventura
yep, no trick, just another set of hands and a lot of on and of and moving the brackets around. the biggest pain is the front latch alignment; 2 years later and mines still not dead on.
