Soft Top back window slide adjustment
Mlarv
TN
It's a nice day here so I figured I would figure out how to open my soft top, and see how it all works. I took the passenger side read window out without issue. I went to the drivers side and it gets stuck on the little nearest the rear door. O got to looking at it and the plastic piece is out of alignment with the longer piece along the bottom. It is down a little. Is there an adjustment I can do or should I take it back into service and let them do it?
Area51BS
Ron
Badlands non SAS 4dr 2.3
Old thread but just ran across it. Might help someone else. Little plastic wedge I made goes under the forward narrow bottom track pushing it downward.
Ford Bronco Soft Top back window slide adjustment 03448610-817C-444D-A526-FD68ED7C9ADC
Ford Bronco Soft Top back window slide adjustment 7E74D367-212D-4566-993F-E28114A03C8B
Ford Bronco Soft Top back window slide adjustment 95C2336C-D3E6-4466-90D3-ECFD4ED589AC
Ford Bronco Soft Top back window slide adjustment EBE1E71C-BEAD-44D1-AA71-770C45EF8A50
Ford Bronco Soft Top back window slide adjustment FCE4DA23-9A3A-4ED4-ACC6-A74BBE312961
mikec426
Russellville, AR
22 4dr Sqtch, '04 Yam FZ1, 22 Versys 1k, 19 Ninja
Got a better picture or description where this wedge goes?
Mlarv
Mlarv
TN
I thought about doing this, but figured I would let Ford figure it out. I went to the service department they wrote it up. They sent me to the body shop. It was the first Bronco soft top they had seen, so I had to show them how to take it off. They confirmed the issue, then took two big crescent wrenches and bent the bracket into the correct position. It took longer for me to get the top off and back on then the repair this. Repair
HoustonPSD
TX
2024 Bronco
This thread helped me today. I didn’t have a wedge and didn’t feel like pulling the soft top off to bend the bracket correctly (will do this someday). However your wedge did make me think of just sandwiching a zip tip between the back side of the plastic slide channel bracket and the metal bracket it mounts to. It worked like a charm. This will be a great temporary fix until I put the hard top back on.
Ford Bronco Soft Top back window slide adjustment IMG_2439
Ford Bronco Soft Top back window slide adjustment IMG_2440
Ford Bronco Soft Top back window slide adjustment IMG_2442
23OBX2.7
AB Canada
2023 Bronco
Mine looks the same I slide in from the back, have rounded edges of the window slides and lubed them...overall it's a poor design but practice makes it easier.
