Small soft top modification to fix uneven canvas
Area51BS
Ron
Badlands non SAS 4dr 2.3
I did a small modification to fix uneven canvas along body line at bottom of side windows. The small plastic piece that accepts the short forward piece of channel on the removable window does not align with longer section. Pics explain better. This is just a quick piece I made as a test. More room for improvement. The wedge shape plastic I made fits between the plastic channel and the mounting surface causing it to angle downward matching piece next to it.
Ford Bronco Small soft top modification to  fix uneven canvas 581926CB-87F9-44F5-8B99-4EEA27405B1D
Ford Bronco Small soft top modification to  fix uneven canvas 5AD0D61E-B576-4070-BF0E-A07488E75D78
Ford Bronco Small soft top modification to  fix uneven canvas 96CDC55F-F6C8-47E9-BDCE-F3FE06EFC176
Ford Bronco Small soft top modification to  fix uneven canvas 8083FA4C-0426-431A-B519-862371B8C2D4
Ford Bronco Small soft top modification to  fix uneven canvas EF8165DF-BABD-4CB4-9D3B-C3521F0F54B2
Area51BS
Area51BS
Ron
Odd how this reposted separately when I pasted it as a reply to someone asking about side windows in another post.
KABQ
Aaron
Albuquerque, NM
Maybe admin thought it deserved its own thread 🤷
Gassyjack
United States
Thanks for the tip, one side of my soft top was misaligned and that fixed it.
Kach Vartan
Los Angeles
Sedan
Hi, I'm looking into this solution, but it wasn't clear to me from the pictures where you install the shim. Can you point it out in one of the pictures you had posted?
Area51BS
Area51BS
Ron
Under this piece. The wedge makes it angle downward better aligning with the rear section. This short piece is typically higher than the rear section. Don’t over tighten or wedge it downward too much as it’s thin plastic. But it really helped. Also would not hurt to round over the edge of channel. The removable window gets hung up easy at the transition.
Ford Bronco Small soft top modification to  fix uneven canvas IMG_1945
Kach Vartan
Los Angeles
Sedan
Thanks, are you putting the shim in from the back side of the short piece, from the inside of the cargo area?
Area51BS
Area51BS
Ron
The backside 2 bolts. It raises the inside therefore pushing the channel down just a little
irishmurph01
Pat
26’ bronco heritage
What material did you use? I’m going to give this a shot
