Sliders & Rock Chip Protection ?
Ksjrb03
Tx
F250
Does your FE have OEM steps on it?
No, it came with the OEM rock sliders ala Badlands. I currently plan to keep it that way, love the look and havent seen another product I would choose to upgrade to yet. If I do swap them out it would be for something that helps with the rock slinging.
Is it truly just the tires? Or is is a design flaw and you are screwed no matter what tires unless you have the mud flaps? (I am also in the camp of mud flaps are ugly as all hell- I am going to get the zroadz side steps though in hopes that will help)
It's definitely the tires. These GY throw rocks like none Ive ever seen. I have KO2s on my truck, and the same drive to work (section of highway recently re-graveled) is a huge difference in rock slinging.
Yep. Bigger problem is preventing all the damage. How far up onto the fender/door is the rock damage occuring?
Pictures posted above show the cone of destruction perfectly. I swear I've had some pings off the windows.
Wolfeman
Little Rock, AR
2019 F150 Raptor
PPF is your friend..
Badlands rock rails won’t do shit to protect, a larger slider/step can help but PPF is what you want for the doors.
My silverado I sold for the bronco had a gellcoat on the rocker panel. Very smart and after 130k miles I had no rock chips
One guy I've seen with PPF on the doors, the PPF is shredded as well.
@BadBlueBronco
Kc
Los angeles
2021 Bronco Badlands
I have PPF on my doors and it looks great. If it’s shredded I feel like they didn’t use actual PPF
@BadBlueBronco
Kc
Los angeles
Yup. But the point I should’ve made clearer is that it throws rocks up through the little gap between fender and slider, AND lower to the ground where it shoots towards the rear fender. Assuming a wider slider/step would solve for the latter, but will need mud flap type coverage for the front doors
The sliders I am having built will have a mini mudflap that fills in that gap. Build updates soon
mandyhoth
Mandy
Explore
Even with the Outer Banks side steps that are lower, I still get rocks hitting my sides with the Sasquatch. I think mud flaps are the only thing that would help with these tires. They pick up everything
@BadBlueBronco
Kc
Los angeles
Wolfeman
Little Rock, AR
2019 F150 Raptor
Lol I think you need to look at the definition of “shredded”
I think we can agree that they are torn - I count about eight tears in a fairly small area. Would be more if the PPF guy had wrapped the edges. Either way, I don't want to pay for PPF when it's going to look like this after each trip down a few gravel roads.
Ford Bronco Sliders & Rock Chip Protection ? img_0169-jpg
@BadBlueBronco
Kc
Los angeles
That’s not a tear, but I get your point. If it makes you feel better I have PPF and have taken it off-road 3 times and totaled 10 hours of forest road travel and it’s still flawless.
RubiconSasquatch
Josh
Denton, TX
2022 BadSquatch, 2021 JLUR, 2008 JK-X, 65 Elco
seems like the fix should be simple - mud flaps and mud tires. The tires being the biggest factor. If you're worried about looks, maybe those two will net out?
BradtheWelder
Brad
Moline, IL
1969 Ford Bronco
My hope my sliders will protect my doors / lower body area. My sliders stick out past the door handles. I purposely started my build on my rock sliders for the protection I hope they will provide from rocks kicked up from tires and door dings. This isn't really a DIY thing that a lot of other people are capable doing for themselves though. One thing I do want to change already is the area behind the front tires I want to close the area between the front fender flare to my sliders. That little area I believe I am still vulnerable.
Link to more pics https://www.bronco6g.com/forum/threads/welded-on-rock-sliders-for-my-4-door.32977/
Ford Bronco Sliders & Rock Chip Protection ? Snap244
Ford Bronco Sliders & Rock Chip Protection ? Snap245
Ford Bronco Sliders & Rock Chip Protection ? Snap247
Marshhunt
2018 RAM 2500
I ordered Rock Slide Engineering steps almost 2 months ago, before I received my Bronco. They are supposed to ship any day. I plan to put a piece of rubber or plastic on each end to connect it to the fender. The 2nd picture is the damage after driving on my 400' gravel driveway twice. Now I use a screwdriver as soon as I hit pavement to clean the tread. Good thing this is not my daily driver.:D
I have had a lot of A/T tires. Never seen anything near as bad as these GY. Some of the rocks hold on until +60 MPH.
Ford Bronco Sliders & Rock Chip Protection ? 1a-900x900
Ford Bronco Sliders & Rock Chip Protection ? 20220128_161430
Battleborn
Robert
Lvnv
Jeep
Got to rokblokz.com
Stampede.Offroad
SD
junk
Yeah, plastic film a fraction of a millimeter thick isn't going to hold up long against a persistent blast of gravel. Most of those films are only rated to last 5-7 years before they look bad anyway.
Mudflaps might not be pretty but they'll work.
