Sirius/XM cutting out issues
MisterMarco
Georgia USA
2015 F150, 2020 Explorer ST, 2022 Maverick, Fusion
I currently own 5 Fords with Sirius subscriptions. My 2023 Badlands Sirius loses reception several times per mile in very clear areas....very annoying as I know it should not do that. My other 4 Fords barely ever lose reception...maybe only under a bridge or heavy cover, but rarely. Is anyone else having issues like this? If so, is there a fix for it?
V1Rotate
Brevard, NC
2022 Wildtrak
Mine used to be great then (probably coincidentally) started cutting out with frequency after an update 6 months ago or so. The only thing you could likely do to make it much better is relocate the antenna from underneath your top to something more exterior
MisterMarco
MisterMarco
Georgia USA
So it's not just me. I just realized the antenna is inside the cabin, not on the outside. That seems odd. Thanks for the reply and suggestion.
Navyicman
Tim
Ct USA
2022 BS Big Bend Area 51
Having the same issue with my OBX with MIC. No issues with my other vehicles. I have had it less than a week and this is my biggest complaint so far.
Taco2Bronco
JP
Tacoma
I have the same issue and yes...pretty annoying.
Sven
West Yellowstone, Montana
67 Bronco,75 F250 CS,88 M35a2c,
With my trailrax and the fact I will never remove my hard top I used this kit. Had to modify the mount plate to bolt to my rack but no more issues. 40 bucks and about an hour.
Ford Bronco Sirius/XM cutting out issues r60301-new-with-logo
MisterMarco
MisterMarco
Georgia USA
The good news is this is my only complaint. I never thought I would be this crazy about my Bad SAQ 2dr.
BigFootie
Wisconsin
Are you using Waze in conjunction? Do you have speed alerts on if you are? The radio mutes for a short time when ever you go over the speed limit.
Navyicman
Tim
Ct USA
I will amend my statement from biggest to only also.
Navyicman
Tim
Ct USA
Nope, I do not use Waze. And it's happening with or without android auto usage. This doesn't happen in my wife's 22 BB Bronco Sport.
Another forum thread suggests signal dead spots, even in cities, but I refer back to it doesn't happen in my wife's BS or in what was my, but is now my daughter's, Malibu.
Navyicman
Tim
Ct USA
Link please?
BigFootie
Wisconsin
It started doing it on my 22Sport this week but I figured out it was Waze. Once I shut off the speeding alert on Waze, the problem went away.
Hope you figure it out. I know it annoyed the hell out of me.
