Sirius Satellite issues after update
Klynch24
Kevin
Long Island
Aviator
Has anyone experienced issues w their satellite radio after the update to sync 4 in the past few days….lux package. Mine seems fine for a while then starts to cut in and out, then fine fire a while then cutting in and out again.
josh1121
Josh
Riverside, CA
Nissan Titan XD Diesel 4x4, LandRover Defender 110
I am having the same issue. I hadn’t thought of it being associated with an update. WT w/LUX
Olds120
New Jersey
2023 Wildtrak 354A
I am having the same issue in my Lux WT. Reception keeps cutting in and out. Very annoying.
PhillySpecial18
Jon
Maryland
2023 Bronco / 2017 Mustang / 2012 Escape
My new BD, MIC, with cross bars/rails seems to have spotty SXM. Is this just ford screwing up again?
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
Had that happen in my previous vehicle. Turned out to be dead spots, even in a major city. If you find it cuts out in the same areas of town, that’s likely your issue.
da_jokker
Jeep Wrangler JKUR
I've seen my Sirius XM do an "update" 2x in the last week or so. I have Ford updates turned off so maybe Sirius is pushing updates and not Ford?
sportcoupe
Georgia
2023 Bronco
My Sirius XM has been cutting out recently when it was fine before. My commute doesn't change. It's either software or the MIC top is blocking it somehow.
rmreid22
Bob
TN
'23 Wildtrak
Same issue with it cutting in and out (even with a clear sky above and no trees blocking)
Decided to try hitting the "reset" button and it seems to have helped (note this will wipe out your phone's BT connection as well as your saved channels (at least it did for me)) but it seems to have fixed the issue
