Sirius presets not switching from steering wheel
Fezzik
Mitch
Massachusetts
2025 Bronco Badlands, 2017 Audi S7
I swear I have searched the forums and have not found this. Please be gentle if it has already been discussed.
I have a ‘25 BL w/various options. When I try to use the steering wheel controls to switch to the next Sirius preset it only switches between the first two. I noticed there needs to be a blue bar above the current preset in order for the steering wheel controls to go to the next preset. If the blue bar isn’t present it will go back to the first preset.
If I manually switch presets I need to hit the preset twice. Once to make the switch and the second time to get the blue bar. It appears to be a known issue on the web. The only advice I found was to do a radio reset (hold radio power + right advance button on the steering wheel for 5ish seconds) or reprogram all presets. I tried the reset option and it worked great….for about 10 minutes. A second and third attempt failed. I have also reprogrammed all the presets in their desired order and in a different order just to see if it mattered. It did not nor did it work.
Any ideas? I haven’t found anything on either Ford’s nor Sirius’ websites and the only options on the web are listed above. Happy for any advice.
CitrusBronco
Everglades
Citrus county, FL
Everglades
You can always try the old standby of discount the battery for 15 min and see if that resets everything.
The only time I had issues with the infotainment the reset you noted worked for me.
Bschurr
NY
Try a reset by pressing in & holding the power button while simultaneously pressing the right seek >> button for about 10 seconds or so and the head unit will reboot.
Darth_JoPa
Joshua
Bay Area, CA
2024 Bronco Badlands Sasquatch
Did you find a fix for this? It's been happening in my 2024 Badlands. Not sure what's causing this failure or how to fix it
Fezzik
Fezzik
Mitch
Massachusetts
None. Thinking of canceling Sirius. It’s their SW issue and they don’t seem to care. May just stick with streaming.
