Shaking and strange noise
Ajschoonover
Andy
Austin
I’ve had the new Bronco Big Bend w Tow for about two weeks. I’m hearing a low rumbling at low speeds and especially on uneven surfaces. It sounds and feels like going 60mph w one window open. I can feel it in my ears. It’s 20x worse and undriveable when I tow something (in my case a 1500 lb aluminum boat). I sent it to the Ford dealership and they hear it but said they have no idea what it is. I bought this car partially so I can tow my boat (which I currently can’t do). Any ideas? I would be very much appreciative.
North7
North Texas
SUV
Check your trailer tongue weight, is it more than 150lbs?
Remove your spare tire, check the pressure relief vents, the four white flaps on the tailgate, do they move freely?
Ford Bronco Shaking and strange noise 021-ford-bornco-spare-tire-delete-wheel-delete-
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
What do those pressure relief vents do exactly?
Obviously release some sort of pressure, lol, but never heard of them before.
  • Like
Reactions: Cat
wrbix
VA and FL
LR Def90, F250 7.3, Caterham 7, LR Series III, etc
Resonant frequencies? - hard to track down, only way to eliminate is change one of the contributing frequencies, ie speed up, slow down, change RPM.etc
MaverickMan
Shane
Sounds like a tire rebalance, unless you hear it more than feel it with your foot on the floorboard. Then the air stuff adds up. A driveshaft imbalance would tear it apart pretty quick, how many miles has it been like that?
North7
North Texas
SUV
Locker Clutch defective, likely assembled that way. 100 miles on it.
No ETA on parts. Can't drive on it or the rear will eat itself.
@Djstang2011 I copied your post from another thread, perhaps your experience will help with the problem in this thread.
What were the indications your rear locker was bad, grinding, vibration, or?
Dads_bronze_bronco
08 JKUR / x_x 00 TJ x_x
What kind of top?
If MIC: remove The panels and reinstall the per the instructions in the manual.
Djstang2011
Darrell
Reading, PA
2011 Mustang GT, 2021 Bronco Badlands 2 door
At first it sounded like a rock in a tire, a thumping sound that followed wheel speed. The more I listened to it I realized it wasn’t a rock, and the sound only happened on decel or coast with no throttle input. Any throttle input would make the sound stop. There was never a vibration that I could feel. I thought it was something stupid like a dry slip joint in a driveshaft or a bad u joint.
I was a little surprised when they told me the locker clutch was bad. The sound started immediately, unfortunately I had the B&O system cranked for the first 50 miles or so. 100 miles on it as it sits right now.
Ajschoonover
Andy
Austin
Every vehicle has them, usually hidden, they let the pressure out of the cabin when you close or slam the door.
Flaps
Also, check all your tire pressures, run them at 35psi and have the dealer re-balance the tires.
Flaps move without a problem
Ajschoonover
Andy
Austin
Tried rebalance and didn’t work. I I don’t feel it in the steering wheel or floorboard. I literally feel it in my ears. Pulsating noise almost like sitting next to a bass speaker.
Ajschoonover
Andy
Austin
I’m about 300 miles in.
