Service schedule and cost
m2vrp
Land Rover
My dealer is trying to sell pre-paid service plans saying the typical service is at 5000 miles or 6 months (In California). They are giving me an option to buy pre-paid service plan that cover 3 yrs / 30k miles / 10 services for about $1800.
5000 miles/6 months seems too frequent, Posting to see what others have been following. And how much does it usually costs.
flip
Phil
IN
www.ruxerparts.com
Fords
Stay at 5K. $180.00 for an oil change and tire rotation seems like a lot. How many miles are you putting on a year? How long do you anticipate keeping the bronco?
m2vrp
Land Rover
I don't expect more than 10k an year
BlueBronco
DFW
$180 per oil change and tire rotation? And maybe one cabin filter and air filter change over that time period? No thanks.
Ford recommends serving at 10k miles. I personally service mine at 5k but others vary depending on driving conditions.
flip
Phil
IN
www.ruxerparts.com
Fords
Here's the big services for a 2.7. Oil at 5K, tire rotation every over or as needed.
IOLM Recommendations
  • Change oil and filter: Gas engine; Up to 7.0 quarts of oil
  • Perform multi-point inspection.
  • Rotate the tires, inspect tire wear and measure tread depth.
  • Inspect cabin air filter if equipped, service as required
  • Inspect engine air filter, service as required
Recommendations
IntervalOperations
60,000Replace spark plugs.(6cyl)
100,000
120,000Replace spark plugs.(6cyl)
140,000
150,000Change automatic transmission fluid and filter.
Change front axle fluid.
Change rear axle fluid.
Change transfer case fluid, if equipped.
Replace accessory drive belt(s) if not replaced within the last 100000 miles (160000 km).
160,000
180,000Replace spark plugs.(6cyl)
200,000Change Yellow Engine Coolant
flip
Phil
IN
www.ruxerparts.com
Fords
There are very few vehicles that meet the technical description of the "normal" maintenance schedule so we recommend 5K or "severe" duty. I have no idea why they say 10K is OK but from our experience it's not a good idea unless it's a diesel running highway miles.
Ford Bronco Service schedule and cost 1682971183413
m2vrp
Land Rover
Thanks for the feedback! Going to stick with 5k then..
And probably will say no to the prepaid plan.
cdoublev
Charlie
Massachusetts
Mini Countryman
@flip curious since you posted for the 2.7, what’s the recommended for the 2.3?
flip
Phil
IN
www.ruxerparts.com
Fords
Oil changes same interval.
  • Change oil and filter: Gas engine; Up to 6.0 quarts of oil
Recommendations
IntervalOperations
60,000Replace spark plugs.(4cyl)
100,000
120,000Replace spark plugs.(4cyl)
140,000
160,000
180,000Replace spark plugs.(4cyl)
