Screeching sound.. Please help
Siborg11
Bobby
Just got my Broncho a few weeks ago. Notice a screeching sound when I open my driver door, coming from the engine area. I also notice it make the same sound when I’m idling (not continuously just every once and a while). Attached is a video, you will hear the sound after 10 seconds. Any help on what this may be and if I should have it looked at immediately would be greatly appreciated.
Thanks
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Thanks
Hi there, I'd be happy to look into your Bronco concerns on my end. Will you send us a message with your VIN and dealership info? I can look into things on my end.
Headsong
Sounds like something's rubbing. There were reports in early Bronc's of hoses rubbing against moving parts....so I'd check those first.
Ravell
Rav
ON Canada
23 Bronco
does it happen only when running? do you have active grill shutters? Unsure if it’s standard option, in any case usually active grill shutters would normally calibrate itself 15 seconds or so after start.. check to see if it’s that.. the first thing i thought of when i heard the pitch of the sound is the servos on my RC stuff
Siborg11
Bobby
I’m not sure on the active grill shutters.. it happens when I open the driver side door while the power is off and then it will do it intermittently while it is turned on
Siborg11
Bobby
I’m no car expert at all but it sounds like metal rubbing on metal
Jayalamo
Jay
Chicago
2023 Ford Bronco Big Bend 2 Door
I have this same issue.
Jayalamo
Jay
Chicago
This is happening for me too
Zstngz
Stephen
Orlando
2012 Boss 302, Datsun Z, Merc E350
Thanks
I have heard this on mine a couple of times.
Siborg11
Bobby
I’m not sure about giving all the information the “Ford” account is requesting because I’m not sure how that helps. I may just schedule an appointment with my local dealer and have service take a look at it.
dejones64
Dan
MN
Bronco 2-dr Black Diamond
2.3, 2.7, manual, auto?
Siborg11
Bobby
Also the sound after I open my driver side door. The Bronco isn’t started, just sitting there.
thesocalexplorer
Southern California
Looks like someone was able to capture that sound while running on video. Wastegate, by the looks of it?
Headsong
