SCCM Program/relearn
Chrome_Pony
Chrome
The Great Land
Installed the new clockspring for the heated wheel and none of the switches function yet.
The Forscan easy mode for SCCM steering wheel right and left switches has a LOT of options, which are all part numbers. Anyone made edits to the SCCM module yet besides Papa Smurf?
BigMeatsBronco
Allan
2021 FE 2 door
Yes, what do you need ? the part number switch left and right?
Chrome_Pony
Chrome_Pony
Chrome
The Great Land
Thanks for weighing in, Meats.
I'm not after the switch part numbers, looking for the correct values for the SCCM module to be entered in FORSCAN. Installed a heated wheel/clockspring/new HVAC and buttons aren't functioning until programmed. The dropdown in FORSCAN even in simple mode is still in HEX edit: they are part numbers and has a ton of options.
I have some more work to do and I need to hook up the battery tender tonight to go back in and I'll try to grab a screenshot of all the options.
BigMeatsBronco
Allan
2021 FE 2 door
I'm not after the switch part numbers, looking for the correct values for the SCCM module to be entered in FORSCAN. Installed a heated wheel/clockspring/new HVAC and buttons aren't functioning until programmed. The dropdown in FORSCAN even in simple mode is still in HEX and has a ton of options.
I have the non easy mode downloaded...one I have is the same across lux models, including Braptor.
BigMeatsBronco
Allan
2021 FE 2 door
this is strange...mine has a list of part numbers on the drop down menu in easy mode. My Ranger Raptors does not, it says "part number not configured"
Anybody with a Braptor wanna check there's and supply info?
To solve this OP needs to download asbuilt ( using a VIN online) for a model that has these features, Heated wheel, Advanced cruise controll, ect... then Save this to your laptop in a file you can find. then in Forescan, upload that file for the SCCM only, and write it. should fix it.
BigMeatsBronco
Allan
2021 FE 2 door
when I search the other part number in the drop down menu, they come up for Bronco sport, Escape, Explorer ext. but none for Braptor p/n left and right.
Chrome_Pony
Chrome_Pony
Chrome
The Great Land
I have a 23 Badlands 2DR Auto with 334A Lux vin and as built, and I'm using As Built Comparison to go line by line and decipher which is needed. Don't have Advanced Cruise, just adding the heated wheel to the High Package.
BigMeatsBronco
Allan
2021 FE 2 door
ok let me know if you get them working, I had to reset the codes that were thown when I switched to Braptor wheel. then the switchs worked.
Chrome_Pony
Chrome_Pony
Chrome
The Great Land
Oh, interesting. Did you just swap your old button packs over to the new wheel? That's what I did.
Chrome_Pony
Chrome_Pony
Chrome
The Great Land
Is there anything special to resetting the codes in FORSCAN? What was the procedure you used?
BigMeatsBronco
Allan
2021 FE 2 door
I first tried just clearing DTCs for SCCM, then I also had to re-download (from saved file) and re-write the asbuilt to it...that fixed it.
Chrome_Pony
Chrome_Pony
Chrome
The Great Land
Somehow the new modules rewrote my asbuilt values? I went back in with the OG asbuilt values for the SCCM and tweaked some other modules and she's up and running.
Realized you were right about the dropdowns being part numbers, so I edited my posts above. Interestingly, my switch part numbers in the simple mode screenshot below are different.
Also for anyone following along don't change the 724-02-01 block to the LUX as built values, it killed my left side button pack entirely. As Built Comparison tool was CLUTCH in comparing two abt files, highly recommend.
Ford Bronco SCCM Program/relearn 1758132762330-44
Heated wheel is awesome! Thanks for the help!
