JetG
Jet
TX & FL
2018 Macan Turbo w/PP & 2016 911 Turbo Vert
what is the overall height? About to have mine done with the exact same set up.
luvmybronco
Loudon, TN
1968 Bronco sport, 1969 Bronco sport, 1990 F250 Lariat 4x4, 2015 F150 Lariat super crew 4x4
What are the advantages and disadvantages of going with perch collars vs. RC 2” level spacers? I’m looking at doing 37’s but not sure if I want to use any spacers or collars. I eventually want to go with King coil overs from Baja Kits but that’ll run about $7500 plus wheels/tires.
Bradley Thornton
Bradley
Hattiesburg MS
18 Sequoia TRD sport, 2021 Badlands Sas, 93 Cobra
luvmybronco
Loudon, TN
azbronco6G
73 Bronco, 21 Bronco
I noticed you didn't do the RC Tailgate Reinforcement bracket for your setup. Are there any concerns with the added weight of the 37" spare tire on the back without it?
Reason i ask is because i have all the same components you have on your build, but i added the tailgate reinforcement. It looks way better without it but i was just curious if you considered that or not a necessity?
Your build looks fantastic, by the way!
https://www.roughcountry.com/ford-bronco-tailgate-reinforcement-51052c.html
ALVA DUDE
1974 Bronco Ranger
My WIldtrak with 37's build so far!
RPG Perch Collars
37x12.5x17 on Method NV's
Rough country 3rd brake relocation bracket
4WP Running Boards/Sliders
Ceramic Window Tint
Ceramic Paint Protection
ADD bumpers and Baja Design light bar and mirror lights and more to come!
I cant really tell; did the collars serve to level as well?
MUDLVR
Justin
Colorado Springs
2022 Badlands Sasquatch
It would be nice if we can add the perch collar with a spacer kit and not mess up the CV angle.
Jose_911
Jose_911
Jose
Scottsdale, Az
Ford Explorer Sport
I’ll have to check tbh I’m not sure.
Jose_911
Jose_911
Jose
Scottsdale, Az
Ford Explorer Sport
Yeah so far no issues I didn’t like the look either. Don’t think it’s a necessity and quite a bit of builds with 37s that didn’t use them.
Jose_911
Jose_911
Jose
Scottsdale, Az
Ford Explorer Sport
I would say so! The front does seems to be slightly higher but I’m sure once the heavier bumper comes in to play it will lower a bit.
Jose_911
Jose_911
Jose
Scottsdale, Az
Ford Explorer Sport
That answers my question, thank you. Guess I’ll do a 1” zone for now on my BadSas and save pennies for the Baja kits later
This is a temp set up until I can get my hands on a set of kings or fox coil overs.
rguest3
Raymond
Florida and Virginia
F-350, F-450, 23 Bronco, 24 Raptor, (2) 77 Broncos
I'm no Coil-Spring expert what-so-ever, but I have a couple questions about this type of lift. Maybe all of this was covered by the experts earlier in this thread???
If I install the 2" Spring Perch Collar for a lift will I lose 2" or so of travel?
Since the Spring now has 2 more inches of Preload would it create a stiffer ride?
Would new Upper Control Arms be recommended for proper alignment?
Your Bronco does look great!
Sassy BD
DD
Las Vegas, NV
89 Grand Wagoneer, 16 Ford Explorer
IMO this is the best WT build I have seen to date. Looks pretty sharp!
kkooch
Conifer, CO
Lexus ES350
RPG Perch Collars
Ceramic Window Tint
Looks super! What does that whole mod cost?
