Sasquatch fitment replacement wheels
Bronc-itis
E
South Florida
Q50 (bronco soon)
I went Sasquatch package because there was so much of it that adds a ton of value and great features. But I’m not really a fan of the wheels. So the idea was to find wheels that can be a direct swap for the stocks while using the sas tires. I really don’t want to use spacers. Rather not even use hub rings. But we may be a little limited on options at the moment.
I really liked the smooth fifteen52’s, but didn’t see one with specs that were close enough to run on the sas tires.
let’s see what replacement wheels you are planning for your squatch while keeping the tires.
Macjr
Martin
Northern NY
Toyota Tacoma TRD Offroad, 2020 Volvo xc40 RDesign
I love the fifteen52 look as well. Let us know what you find out for replacements
Bronc-itis
Bronc-itis
E
South Florida
Q50 (bronco soon)
I’ve been searching but not much is available in a 17.
Detroit Steel is in development of a Bronco specific line of wheels. Unfortunately the smallest will be an 18” wheel. Which sucks because I wanted to keep the same tire size.
But I’m okay with bumping up to the widest track tire I can get on an 18. Probably doing something like this for tires. Much better in the wet, and a more streetable tread pattern.
https://www.nokiantires.com/all-season-tires/nokian-rotiiva-at/user-opinions/
And a set of “Smoothies” from these guys.
https://detroitsteelwheel.com/wp-content/uploads/2020/10/2020-Detroit-Steel-Wheel-Catalog.pdf
JBowles
Jordan
Ozark, MO
Ram 2500
Method has there 703 in a 17x8.5 with +35 offset, thats pretty darn close to OE Squatch wheel
FlyingScot
Tomball, TX
2022 Wildtrak 4dr
Following out of curiosity. I'm not a fan of the tons-of-fasteners look (and weight) that go with beadlock-capable rims, and no desire to stray far from the stock offset value and have the tires poking out of the fenders.
Other than the aforementioned Method 703s, I haven't had a ton of luck looking for 30ish-mm offset 17x8.5s, and unfortunately those only in black and bronze, not the gray for whatever reason.
RoLyMa27
Rodney
SloKart, TX
21 Bronco 2dr, 26 Explorer ST
Jordan, I can't seem to find the 703 in that size with that offset? I am looking on Method's site, where did you find it?
JBowles
Jordan
Ozark, MO
Ram 2500
For what ever reason is only on the Black and Bronze 703s and not the titanium ones
Ford Bronco Sasquatch fitment replacement wheels 1626103608134
RoLyMa27
Rodney
SloKart, TX
Ok, that would be the problem then, I was looking at the titanium! Thanks. Edit: I don't understand why they would offer that offset in black and bronze and not titanium. Doesn't make a damn bit of sense!
Bikeric
Tulsa
2022 Badlands LUX on 37's
I went Sasquatch ....... So the idea was to find wheels that can be a direct swap for the stocks while using the sas tires. I really don’t want to use spacers. Rather not even use hub rings. But we may be a little limited on options at the moment.
Using hub rings is no big deal. Any wheel built to fit a Toyota Tacoma or 4Runner will match the bolt pattern, and a thin hub-centric ring can be used to make up the bore difference. If SAS wheels are 17x8.5 +30, you should easily find aftermarket alternatives. FYI, I looked up prices for the rings to convert the stock SAS wheels to true beadlock and they cost $200/each. OUCH!!
Bronc-itis
Bronc-itis
E
South Florida
Q50 (bronco soon)
Using hub rings is no big deal. Any wheel built to fit a Toyota Tacoma or 4Runner will match the bolt pattern, and a thin hub-centric ring can be used to make up the bore difference. If SAS wheels are 17x8.5 +35, you should easily find aftermarket alternatives. FYI, I looked up prices for the rings to convert the stock SAS wheels to true beadlock and they cost $200/each. OUCH!!
I get it. Just trying to avoid using extra shit to get wheels fitting right. I’m pretty sure I’m going with steelies
wilbersk
Sean
2023 Bronco Raptor
SAS wheels are +30 offset, not +35
FlyingScot
Tomball, TX
2022 Wildtrak 4dr
Two others I've found, not quite the same offset (+25mm), but close:
Icon Vector 6 (~$245, 30 lbs)
Method 313 (~$385, 25 lbs)
Curiously the Method part number does not appear on their website, although it is all over the retailers and even part of their pictures on their own page:
Ford Bronco Sasquatch fitment replacement wheels 1626107126933
ETA: The Icons are spot on with the factory center bore diameter at 93.1mm, the Methods are a little bigger at 106.25mm
