Sas take offs what do i have
Boltstop
Rudy
Idaho
69 Bronco 302
So I thought I had the right bilstein takeoffs and was having them installed on Tuesday but I'm not sure now . I'm starting with a 23 base 2 door 7 speed now I have to make sure I have the sas set of bilstein's not the badlands. What says the hive .
2ea mb3c-18045-rbj
2ea mb3c-18080-rbk
Will these give me a sas lift without spacers Thanks
F OR D
BD Green Machine
Use this chart to find your front/total and look at the takeoffs to get the difference.
You have 2334/4286
I think my difference was 133/90 after I added winch, etc. and it was perfect for a level. I used a BL non-sas, and yes, it will give you a few inches. If you got that one from the Idaho thread you are going to be +200ish for f/r.
Boltstop
Boltstop
Rudy
Idaho
69 Bronco 302
That doesn't answer my question what shocks do I have ?
CitrusBronco
Everglades
Citrus county, FL
Everglades
It looks like yes you have Sasquatch shocks.
As a additional data point these are off my 24 Everglades.
Front = MB3C-18045-RBK
Rear = NB3C-18080-RFC
Boltstop
Boltstop
Rudy
Idaho
69 Bronco 302
I understand I can run those on a 2 door ?
F OR D
BD Green Machine
LOL you said they are take-offs. Ask the seller what it came off of. You can also search this forum but let me post the link:
https://www.bronco6g.com/forum/thre...ghts-with-wheel-tire-sizes.17719/post-1555139
You need to find the bils you are putting on (look at the link and confirm), use the chart I posted and find your current vehicle and compare the weights.
Yes, the bils will be fine, it's the spring weight that may get you (height or ride quality). I put 4d non-sas bl bils on a 2d. Others did 4d sas to 2d. It's a pretty direct swap. Slightly more plus in the front is a benefit to cut the rake too.
Make sense?
Edit: I dm'd you.
Boltstop
Boltstop
Rudy
Idaho
69 Bronco 302
Just to be clear I'm installing sas bilstein takeoffs off a 4 door v6 auto on a base 7 speed 2 door along with the upper arms
GroovyGeek
Boyan
'23 Bronco BD
Probably don't need UCAs.
F OR D
BD Green Machine
Which model?
UCAs are all the same sas or non-sas unless you are getting different ones.
Boltstop
Boltstop
Rudy
Idaho
69 Bronco 302
Got her done gained 2" up front and 1.5 in the back , it's leveled up and drives straight I don't think I'll need a alignment but I'm going to have them check it out thanks guys the information is greatly appreciated
