Rubbing on swaybar
ICUGAZN
Kevin
Woodbridge, Virginia
2019 Raptor
I have 37" BFG KOs on stock SAS wheels. I get no rubbing full lock driver, but full lock passenger I get rubbing on the swaybar. What would you recommend for offset to prevent rubbing? Also, would you consider spacers over new wheels to fix this? Thanks.
BudgetBronco
Tim
Pittsburgh, PA
www.youtube.com
I assume you mean rubbing on the inside sidewall of the tire. If so, and the rubbing is slight and only on one side, a little more pressure in the tire might be enough to reduce the amount of bulge in the sidewall and the rubbing goes away.
That is not a bad idea - but won’t work if off roading and airing down.
If it were mine yeah I would try some small spacers — as little as you can get away with. Kinda suprised you are seeing it at all with the SAS rims though.
ICUGAZN
ICUGAZN
Kevin
2019 Raptor
Yeah I was suprised as well. Are spacers relatively safe? What are the best brands? Thanks.
BroncoAdventure
Alabama
'24 Bronco 4 Door
I'm running 1" Mishimoto spacers on my non sas, Black Diamond with sas rims fitted with 37 KO2s. No rubbing anywhere. 2 years no issues.
