RSE Steps + Body Lift?
Anyone done a body lift with Rock Slide Engineering steps?
They have a bracket that slides under the washer for the mid body mounts. But with a body lift, the rest of the step is mounted to the body and you can't get the bracket on the lower part of the body mount any longer.
Not sure if anyone has done this. It looks like you could just leave the bracket off and probably be ok, but it sure does look like it adds a bit of beef to the slider for big hits, letting the frame help absorb some of it.
Official response from RSE:
Hello thanks for reaching out. We don't recommend using our sliders with a body lift as it makes it so some of the brackets are not used.
