Roof panel latches
Knelson
Kerry
Tulsa, Ok
2018 4Runner TRD Pro
My wife received her 2 door Black Diamond from Dirt Mountain last week. Today she said it was leaking from roof on driver side. I looked around and notice that the L shaped latch on the driver's side is shorter then the one on the passenger side. It barely latches. It looks the same size as the latches that are on the side over the door. Can someone with a 2 door hardtop take a look at their latches and see if her latch is correct? Are they supposed to be the same size? Thanks.
Ford Bronco Roof panel latches PXL_20211028_003147149
Ford Bronco Roof panel latches PXL_20211028_003124282
Theherofails
Thomas
Phoenix
I'm in a 4 door, but I checked anyway. Something off there, friend. All of my latches have a good inch of engagement.
Ford Bronco Roof panel latches 20211027_181001
Baddie64
Paul
OKC
2005 Jeep Liberty, 2013 Ford Fusion Titanium
Report that to the dealer.
Dads_bronze_bronco
08 JKUR / x_x 00 TJ x_x
Take the tops off, and put them back on yourself being very careful to follow the instructions.
Also - while the tops are off, check to make sure the bolts for the clamshell are installed correctly.
I bet you get them aligned right when you reinstall the t tops.
Theherofails
Thomas
Phoenix
Worth a shot, but there are alignment pins to make sure it all lines up. Hmmm.
Knelson
Knelson
Kerry
Tulsa, Ok
I went and measured the latches which I should have done before. The driver side latch is 1/2 inch shorter than passenger side. Maybe quarter inch of engagement.
Orjeepguy
Oregon
Bronco, Black Diamond
Saw this post last night while I was in bed. Too lazy to go look. Just remembered and took a look.
You are correct, they assembled it with the wrong latch. Used one of the outer short ones. :confused:
Sorry for the poor photo. It's dark in my garage.
Ford Bronco Roof panel latches 20211028_173807
Ford Bronco Roof panel latches 20211028_173829
Techun
Pa
BD, 2.7, MIC, 4dr
There's no way to align them wrong
Knelson
Knelson
Kerry
Tulsa, Ok
Thank you. Picture proves what I thought.
