Rock slide engineering step issues
Rancid
Ryan
Cincinnati Ohio
Bronco outer banks
Hey guys. I have recently installed some RSE 4 door steps on my 21 bronco and got as far into the motoroso install video where you place the fuse inline and the steps are supposed to function check themselves. The passenger side functions as expected by going down and up once but there is no movement or noise from the drivers side. Following the recommended steps I then took the steps back off and tested the motor to direct power and the functioned without flaw. I’m at a loss and would love to figure this out this weekend and rather not have to wait till Monday to call RSE so any help is appreciated. Thanks
GLOCK10MM
Don
Rubicon 2015 & 2004 2500 CUMMINGS
I had an installer do mine (being old isn't fun) & my guy had a wire backwards that developed a similar issue. I wasn't there during the instal. I can tell you once they are done these steps are awesome ! Best of luck, sorry I can't offer any help.
Rancid
Rancid
Ryan
Cincinnati Ohio
Bronco outer banks
I appreciate the reply I’ll double check the wiring to be sure but think it’s all good on my end I’m worried it maybe the circuit board but we’ll see on Monday when I give them a call.
Calm horse
MO
Georgia
17 f150 king ranch
One of your magnets may not be making contact properly..
Had multiple problems with mine..( most have been magnets..) had to replace motor module on driver side and an o ring on step...RSE has fantastic customer service if needed...absolutely live these sliders...they'll save your seats from wear and tear and also protect from rocks from the trash good years
Rancid
Rancid
Ryan
Cincinnati Ohio
Bronco outer banks
I haven’t gotten to the point of putting the magnets on yet on the install. We were following the motoroso video and in the video after putting the sliders on ( and before doing any of the interior stuff like the magnets) you put the fuse in the harness to let the steps calibrate. My passenger side did as expected (go down and back up) but my driver side did not move at all. Would you think that because I don’t have the magnets in that it’s causing the issue?
Calm horse
MO
Georgia
17 f150 king ranch
Yes hopefully....
Calm horse
MO
Georgia
17 f150 king ranch
The reason I think that is because I have had magnets come loose and it messes the module up and will cause it do some weird things. And then once I corrected and reset ..they worked
Rancid
Rancid
Ryan
Cincinnati Ohio
Bronco outer banks
Amazing I’ll give that a shot and see if that helps as well. Really appreciate the feedback.
Calm horse
MO
Georgia
17 f150 king ranch
No problem..hopefully this helps taking these steps off and back on gets tiring.
ksdon
kansas
We got some 2.25" x 3/8 neodymium bar magnets. We stuck them to the door with Gorilla rubber tape. They really helped make our steps 100% reliable. The RSE magnets require a precise fit and ours seemed to move a little. The above fix solved it.
Rancid
Rancid
Ryan
Cincinnati Ohio
Bronco outer banks
Just to clarify. Was your issue the steps not dropping or not rising? Because I maybe mistaken but I thought with a lack of magnetic sensing it would effect the steps not rising when you want them to rise not my issue of not doing anything at all.
C1 Ret
Dennis
Reno, NV
2022 Bronco
They should drop when the sensor is away from the magnet. It sounds more like a power issue.
C1 Ret
Dennis
Reno, NV
2022 Bronco
Do you have a multi meter you can use to verify power to the driver's side step?
rtaylor
R
ID
19Raptor, 22Bronco
Note that the updated low-power controllers don't seem to cycle the steps when applying power. That was the first thing I noticed after updating the controllers. They appear to cycle when you close and open the door the first time. If you purchased the steps recently, you might have the updated controllers (the new ones are cased in black plastic, old design is white plastic).
I prefer the screw-down magnets (throw away the outer keeper):
Ford Bronco Rock slide engineering step issues 1700945942636
Rancid
Rancid
Ryan
Cincinnati Ohio
Bronco outer banks
That’s what I figured as well. We put it to a multi meter to both the driver and passenger and both sides read zero which was weird considering the passage was functional
