Rock Rails & Steps
EBRU2024
Elizabeth
Hudson Valley
21 Audi Q7, 13 Mini Countryman
Hi! I understand the function but don’t want visible holes on the side of my bronco with any of the step options offered through Ford currently. The rock rails hide the holes which I like but I’m short and I need a step to get in. Does anyone have recommendations for steps that will have a rock rail like piece that covers the holes?
Ford Bronco Rock Rails & Steps IMG_0925
Bonnie6G
Kyle
Denver
Badlands LuxSquatch
Rumbloki
Alton
ATX/PCB
ZR2, 1973 Mach 1
If you don't do any serious rock crawling the factor "Removable Hoop Steps" should work for you. The steps unbolt for clearance, but the remaining rail is not designed to take a hit. Finding a pair in the classifieds is your least expensive solution.
Ford Bronco Rock Rails & Steps 20230820_102414-50
EBRU2024
EBRU2024
Elizabeth
Hudson Valley
Doc TOC
Los Angeles
Expedition Max, Fusion Hybrid, BMW 5 Series, HD Road King
What can you afford?
How do you want it to look?
Are you an off roader or overlander or mall crawler or or or?
Appearance or function? Rugged or boojiey?
Do you know the difference between a wrench and pliers?
The solutions range from just seam covers (IAG Off Road $100) to integrated, automated steps on a rock slider (Rock Slide Engineering $2,400) and a lot more in between and more so ($$$$).
And who is installing it (dealer, you, shop, family member) ? That's at least a few beers more.
Use this site's search function and the "Similar Threads" section (below) to see what other members have done. That should get you headed in the right direction. Have you done any google searches yet? That will help you narrow down what you like or don't like.
Then certainly come back and get some member input on their experience to see if a product meets your needs and wants.
Happy shopping.
EBRU2024
EBRU2024
Elizabeth
Hudson Valley
They didn’t have any tube steps on the lot fit me to see… looks like they hide/cover the holes?
Rumbloki
Alton
ATX/PCB
ZR2, 1973 Mach 1
They do and they don't flex when I bounce 250lbs on them.
I switched mine out with frame mounted sliders due to the rocks in my area. I got them because I bought from dealer stock.
EBRU2024
EBRU2024
Elizabeth
Hudson Valley
Happy shopping.
I’m a mom of a two year old so more like a grocery store and toddler schedule crawler. I will not go off-road but live in a mountain area that has had crazy storms this year causing rock and mud slides so the off road capabilities may prove handy! I’m in the process of deciding the configuration of a Wildtrak which I test drove yesterday against an outer banks- I liked the drive better and the look. I’m going to customize it though and having the hard top painted to match the white body, the front bumper mirrors door handles and fenders body matched too. I’m debating adding the ram hood. It would be professionally installed- I don’t have a “budget” per se just gathering information while I’m in the configuration stage right now.
Murraydog11
Rick
2021 2Dr Outer Banks, Jeep Cherokee
If I'm not mistaken, you're referring to the pinch welds below the door. Ford, as well as after market companies make a pinch weld cover. I have the Ford OEM. I have the OEM running board. When I picked it up, it showed the pinch welds. Once I had the cover installed, it looked much cleaner.
Before:
Ford Bronco Rock Rails & Steps mybronco5
After:
Ford Bronco Rock Rails & Steps 20220209_091803
EBRU2024
EBRU2024
Elizabeth
Hudson Valley
Awesome great information add
Before:
After:
exactly what I was referring to! This is amazing information now I know the right terminology and the solution! Thank you!
Doc TOC
Los Angeles
Presume you are looking at a 4-door for the 2nd row car seat for the next 5+ years.
Knowing you will be in and out of that 2nd row a lot, I suggest getting a full length rail instead of steps. Many times it will be you and your toddler on the rail behind that 2nd door. You will be glad for the extra space length. IMO you may be disappointed by a drop step.
And the Wildtrak is taller than an Outer Banks. So, if a Wildtrak is your choice, look for a rail with some drop-down, or the Rock Slide Engineering rock rail. Your toddler will need that lower step as much as you will.
I don't know what your dealer custom shop has on display. Take a trip to a local 4x4 shop (doesn't matter if they're a Jeeper). They probably have several options you can visually see what it would look like on your Bronco.
Dreamer
Kevin
Connecticut
Ford Mustang GT convertible
There are steps/stirrups that can hang on and attached to the factory rock rails. I ended up going with the Rockslide Engineering power step rails. They are spendy but worth it in my opinion.
https://www.bronco6g.com/forum/threads/side-steps-for-oem-rock-rails.69743/
https://rockslideengineering.com/product/bronco-4-door-step-slider-2-box-set/
I may not be correct, but what I think you’re saying is you don’t want the pinch weld holes to show with the side steps that Ford offers. You can always can get a pair of pinch weld covers that cover the holes. They are reasonably affordable from various sources.
EBRU2024
EBRU2024
Elizabeth
Hudson Valley
thanks for the advice- it’s helpful and now I know about pinch weld covers so I think that expands my options!
EBRU2024
EBRU2024
Elizabeth
Hudson Valley
Exactly and because of this tread I learned something new today. Thank you!!
Dreamer
Kevin
Connecticut
I feel the same way. I don’t like the way the holes look either. Good luck.
