Rigid 360 pod with backlight
CUPRA
'21 Bronco OBXSAS/'23 Camaro SS Convertible
I see you got a 2-pin 16 gauge wire. Doesn't the Rigid light have 3 wires for hookup? Two wires for the light and one wire for the backlight? How did you hook up all 3 wires?
One of the wires is a ground, and in the Ford Performance instructions, they show that you can ground the lights on each side of the vehicles.
The left one on the left fender frame and the right one on the right fender frame, that way you only have to run two wires over to the power source in your case, for the backlight and the main light.
KompressorV12
KompressorV12
Portland, Oregon
19' Jeep Grand Cherokee High Altitude
360 has three wires. One for back light, one for main light, one for ground. That wire is just wire. You can split the two wires apart and make your own length.
TigerBronco
Charles
2011 F-150 F/X 4, 2019 Honda Odyssey, 2001 Nissan Pathfinder, 1992 BMY M923A2 M
Your video on the install was great! Just got my Ford performance version. Mine didn't come with the bolts, or the washers, for mounting the brackets to the Bronco. Any idea what the specs are on the correct bolt? The Ford Performance instruction sheet just lists it as "bolt".
CUPRA
I believe you can get away with M8 bolts, that seems to be what all the other bolts are for the most part on the Bronco, but without taking it apart and trying, I can't give you a definitive answer.
And yeah, I don't know what's up with the RIGID kits, mine had the bolts, but didn't have the washers, I had to scavenge a couple from a neighbor that would work correctly!
dooberj
Robert
Jackson, MI
'22 Bronco
Haha. Gotta try right. I appreciate it and won't rush out to get new wire like I was going to at least.
@ScoutandBronco I have to ask, did you try?? I just picked these up from the Ford dealer along with a 40" light bar... I'm going to install them this weekend, but don't know if I'll bother trying to get the backlight going.
Lak34ers
Troy
Seattle
Guaranteed won't work with Ford Performance version. I tried and spoke to Rigid it is disconnected internally. I'm running a dual rigid setup ford performance driving pods inside and rigid spots on the outside...spots (non ford) have backlights that work...performance does not. Also, different brackets so I had to paint the non ford version black to match. Non ford bracket sits a little lower. I actually don't mind that they are different since it shows a stagger in height. Also went to the local hardware store to get black stainless bolts/washers/nuts to match it all up. Came with bright stainless.
Ford Bronco Rigid 360 pod with backlight Dual Pods
dooberj
Robert
Jackson, MI
'22 Bronco
Thanks man! I like the setup you went with! It looks like I'll save myself some headache and forget about even trying. Not too disappointed since backlight isn't mentioned when ordering at all. I had a boatload of FordPass points saved up, so got $1700ish worth of lights for a couple hundred bucks so I'll just roll with it...
Lak34ers
Troy
Seattle
You running the modular steel bumper or plastic standard?
dooberj
Robert
Jackson, MI
'22 Bronco
Modular steel bumper, they took my color away they weren’t taking my bumper away lol
Lak34ers
Troy
Seattle
Good move. I got a plastic bumper but just put the Diode Elites in it and it is growing on me for now...
ScoutandBronco
Grand Haven, MI
1966 International Scout, 2012 Jeep Grand Cherokee
I didn't. I determined I didn't care enough to have backlighting so didn't try. Sorry I couldn't help.
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
I know this is an old post. But if you need some Rigid lights check out our site at www.4x4TruckLEDs.com - We're a Rigid Industries dealer. We also stock other brands like Diode Dynamics and Baja Designs.
We KNOW Broncos!
ravenvoyager
St. Albans, WV
24 Bronco, 23 Scat Pack Challenger
Yes actually you'll have 3 wires. Power, Ground and then the back-light wire.
Rather then buy on Amazon why not support one of the vendors (like us) as we're a Rigid dealer:
https://www.4x4truckleds.com/rigid-industries-360-series-4-pair-drive-amber-backlight/
I try to help out the small shops but if something goes wrong during transit/shipping and I don’t receive the item for whatever reason Amazon always has my back. I’m having issues with an order from Oracle right now. Also, I was hoping to get the item quickly because it’s holding up this install. I’ve been waiting on delivery for a week and a half now and it was sent via usps snail mail. I did try to price other shops for the item and was even given a discount code from a few online shops, but still got a better deal through Amazon. I have purchased products through IAG and the customer support and tracking have been phenomenal.
4x4TruckLEDs.com
Adam
Lindenhurst, NY
I'm not Oracle though, I'm 4x4TruckLEDs.com
Most of our customers get product within 1-3 days. You can always ask us "Hey how long till I get this" and we can tell you. Did you ever contact us for a quote or availability?
OracleLights
New Orleans, LA
www.oraclelights.com
Sending you a DM so we can get this sorted out for you!
