pics or it didnt happen?I built mine from aluminum angle and a half sheet of aluminum from a box store for my 2 door. It held up 5 bags of salt no problem.
I may make a few and sell independently…pics or it didnt happen?
What's a kitchen draw?Too bad it doesn't slide out/removable like kitchen draw.
You operate an armory? "Cause there's plenty of room for rifles and ammo in a Bronco. You don't need a Bronco XL for that.I needed enough room to transport the rifles and ammunition.
Who doesn’t?You operate an armory? "Cause there's plenty of room for rifles and ammo in a Bronco. You don't need a Bronco XL for that.
Our brackets mount to the soft top's OEM cage hole locations.Are you still able to remove the soft top with this installed? I moved my spare into the cargo area and this seems like a good way to box it in there.
21".What is the distance from the bottom of the rack to the floor?
I want one of these for this purpose alone for the 2 door! I built one with 1x1 frame with two individual pieces of plywood that I have to build/unbuild in place but an aluminum one would fit the bill!A bunk bed for your dogs!
Distributed evenly, 200 lbs.Any idea on weight capacity?
following2 door in the works - available after Great Smokey Mountain Jeep Invasion.
