Reverse lights (cube) location ideas
MagicCecil5530
South Carolina
2021 Big Bend 4dr
Anyone have some good build pictures of where they put cube lights as additional reverse lights?
My initial thought was under the rear bumper next to the shackles but now I’m worried about ground clearance with them after thinking about it.
Would love to see some ideas!
Ford Bronco Reverse lights (cube) location ideas D4BEF286-6C8E-43B6-8B14-578380E2CCCE
Dadsquatch
Brad
Chandler, AZ
2022 Ford Bronco
MagicCecil5530
MagicCecil5530
South Carolina
2021 Big Bend 4dr
Dadsquatch
Brad
Chandler, AZ
2022 Ford Bronco
My plan currently is to do them where the 3rd/4th links are installed. Just wondering if ground clearance will be an issue
Clearance may be a slight issue......depends on what sort of off-roading you plan on doing. If you're also planning on using the reverse lights as chase lights (by adding a yellow/amber cover to them), then you don't want them down low below the bumper. They really should be up higher where more visible (i.e. at the spare tire level or above).
MagicCecil5530
MagicCecil5530
South Carolina
2021 Big Bend 4dr
Most of my off-roading is hunting related, I don’t do any rock crawling or anything. I also added D-rings on the back on both sides where the tow hooks were so they might sit even with them which would help. I don’t even know what chase lights are lol
Dadsquatch
Brad
Chandler, AZ
2022 Ford Bronco
Then I'd say you're all good with putting them down lower next to the D-rings like you mention.
Dadsquatch
Brad
Chandler, AZ
2022 Ford Bronco
swooshdave
Portland, Oregon
Mustang
Dadsquatch
Brad
Chandler, AZ
2022 Ford Bronco
I have the first one also.
Nice! Can you share some completion pics? I have the SC2s for mine, and am a little afraid they may be too big and should have got the SC1s.
Bikeric
Tulsa
2022 Badlands LUX on 37's
Which bumper do you have? The first pic looks like a plastic bumper, but the second pic looks like a steel bumper.
It's a HAVOC Steel Bender rear bumper. It's a good deal at only $500, but it's a pretty thin walled. My exhaust tips bent it on a hit which must be where the Bender name comes from.
Ford Bronco Reverse lights (cube) location ideas txNbnxG
Ground_zero298
Scs michigan
6 ss1’s in the rear bumper and a pair of ss3’s on the diode spare tire bracket.
Red back lights are on with parking lights. 2 switches, one for the ss1 and one for the ss3. Allows no activation, reverse trigger, and constant on.
Ford Bronco Reverse lights (cube) location ideas B928594E-7B5D-4661-9ADE-EE7583243A50
Ford Bronco Reverse lights (cube) location ideas C9785B6A-252E-4D14-9DD3-81D03EC5688E
Ford Bronco Reverse lights (cube) location ideas E21D66C1-DA6B-4A71-814E-A2860B5E87F4
Ford Bronco Reverse lights (cube) location ideas C594C908-583A-4512-8130-33E3FC8AA210
Ford Bronco Reverse lights (cube) location ideas F0286FED-F229-42E2-BE9A-A969EB46A9EA
swooshdave
Portland, Oregon
Mustang
Yeah, gimme a few days. The rig just got off the train and isn't at the dealer yet. :D But it'll be one of the first things I put on. After the steps so the wife can actually get in...
Dadsquatch
Brad
Chandler, AZ
2022 Ford Bronco
Ahhh gotcha. In that case, I'll probably have mine installed before you (likely later this week or weekend). Which size Diode lights did you get?
