Reverse lights (cube) location ideas
MagicCecil5530
MagicCecil5530
South Carolina
2021 Big Bend 4dr
Ended up going under the bumper on the corners. Will send pics when it’s done
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
Anyone have some good build pictures of where they put cube lights as additional reverse lights?
My initial thought was under the rear bumper next to the shackles but now I’m worried about ground clearance with them after thinking about it.
Would love to see some ideas!
We already sell a few kits for this
Baja Designs
https://www.4x4truckleds.com/2021-ford-bronco-reverse-light-kit-w-baja-designs/
Ford Bronco Reverse lights (cube) location ideas 1674586973751
We also have a Diode Dynamics Kit as well (this kit plugs right into the back of the trailer connection, real easy wiring)
https://www.4x4truckleds.com/dual-l...-diode-dynamics-lights-7-pin-trailer-harness/
Ford Bronco Reverse lights (cube) location ideas 1674587051212
Baja Designs
San Marcos
I’m running Baja Designs in an LOD bumper. I have them running off of an aux switch, but would be easy to run them off the reverse light circuit.
Looking clean (y)
Best,
Brahian
01tundra
Middle TN
2003 Toyota Tacoma / 2021 Nissan Titan XD
I put some morimoto 4bangers inside the spare mounted to the spare mount.
I like this!
I'm planning on purchasing the Diode Dynamics Stage Series Reverse Light kit with SS1 Pro's from 4x4TruckLEDs, but instead of using their mounting bracket, mounting them like you did inside the spare.
I'll likely have to extend the harness a little between the lights, but that's simple..
Dadsquatch
Brad
Chandler, AZ
2022 Ford Bronco
I like this!
I was thinking about the same idea as you this morning. I already have the kit you mention, but with the SS2s. I haven't installed it yet. They are a bit too big to fit between the holes in the Sasquatch wheels, so I was then contemplating the SS1s. So I took some measurements and think the SS1s will be too far back / not flush enough with the Sasquatch spare wheel. Mostly because the bracket for diode lights is very small. So I think the bracket may be more of a problem than having to extend the harness. Thoughts?
01tundra
Middle TN
I was thinking that I could use spacers to adjust the mounting position of the brackets if needed.
Dadsquatch
Brad
Chandler, AZ
2022 Ford Bronco
Not sure I follow with the spacers approach. Can you clarify? I'm up for ideas as I want to try to implement this as well.
01tundra
Middle TN
To space the light brackets out away from the tire mount far enough such that the lights align with the holes in the wheel.
AKBronc49
Russ
Anchorage, Alaska
So my summer wheels are my factory Sasquatch wheels, I have not tried test fitting them yet as I'll run my winter wheels/snow tires until April weather depending.
Luckily being so far north I don't really need lights in the summer. (Thank you midnight sun!) So I may just remove them for summer..not sure yet.
Dadsquatch
Brad
Chandler, AZ
2022 Ford Bronco
Got it. To me though, the concern is getting the lights to extend flush/outward just a bit with the holes in the wheel. That way the lights aren't lighting up a bunch of the inside of the wheel and projecting more outward. But yes.....spacers would help get them centered more with the holes in the wheel, just probably not pushed outward more.
01tundra
Middle TN
I figured with the smaller lights, them being recessed may not be as big of a deal.
Dadsquatch
Brad
Chandler, AZ
2022 Ford Bronco
Good point. I'll take some more measurements tonight and will try to report back.
Jpursuit
J
Houston
2008 f250 king ranch 4wd, 2021 Bronco
Baja Designs
Baja Designs
Jpursuit
J
Houston
[/QUOTE]
I installed baja designs SS1 reverse light using the 4x4truckLED bracket and harness kit.
With the SS1 (small single cube) light you can loosen one nut on the bracket behind the bumper and rotate the light upwards to be fully inside the rear bumper. Don't know if rotating the SS2 lights, which they also show here, would also fit inside the bumper.
I added these as backup lights after tinting my hardtop and now I can easily see behind me in the dark. The low mount also doesn't create glare problems for the camera.
