Reverse and the rear end squats
Bucking_Will
Will
Irvine
2024 Bronco
Hello everyone I tried googling and searching the forum with no luck.
When I put the bronco in reverse the rear end squats and then when i go back to drive the rear end lift……is this normal? And if so why?
It’s a 2024 Wildtrack HOSS 3.0
CatMonkey
Lafayette LA
2023 Bronco, 2012 Shelby GT500, 2021 Shelby GT500
I have a 2023 Wildtrak and just replaced my headlamps and it's really noticeable. I didn't notice it quite as much as the OEM headlamps and I don't really notice it at all without the beams on. I think the springs are so soft it just makes more of a transition between drive and reverse than anything I've ever owned.
Bugkillah
Keith
North Augusta, SC
Base Sas, Badlands, Wrangler, Nissan Frontier
More noticeable with a lifted vehicle that has a lot of suspension travel. Not near as noticeable with a sports car and almost no suspension travel.
Bucking_Will
Will
Irvine
2024 Bronco
OK thank you for the feedback....as that makes sense and I am running eibach springs as well.
DrillRX
Bakersfield, Ca
2024 Ford Bronco BB SAS 2 Door 6 speed
It’s called “axle wrap”. All vehicles do it to a certain extent depending on suspension type and capacity. In the “old days” you’d add a “traction bar” (not to be confused with a track bar) to the suspension, mostly used on cars with soft suspension and high HP/torque to reduce wheel hop and increase traction during hard launches associated with drag racing. Nowadays they’re called “Anti wrap” bars/links.
