Rethinking SaS
Skip2a
Pat
Pennsylvania
2020 Sahara
I saw a Badlands in person the other day and I was impressed with the stance of it and it’s overall appearance.
I ordered a SaS package on my 2 door BD to get the lift and bigger tires. I will never use the lockers: she will be my daily driver and any off reading will be mild.
Is there a way for me to get the stance/look of the Badlands with my BD? Will the stock rims allow me to switch to 33’s and not have to buy the SaS? I’ve seen several 1.5” lifts available for other brands that look easy to install (they look like fiber discs).
I‘m not sure how the 35’s are going to handle or last on the road.
I‘m probably looking at a $3k savings that I can put towards a trailer that I will need after trading in my truck.
ZackDanger
Z
Massachusetts
2021 Toyota 4Runner
If all you want is the stance, then yes, it will be cheaper to do it yourself.
But the Sas is more than just wheels, tires, and lift… so you have to weigh if you want any of the other things (including different diff gearing, wider flares, upgraded axle…) or the additional capabilities (longer suspension travel).
Geekytrails
Evan
Dayton, OH
Acura TL Type S
There have been a couple posts with people upgrading to 33 tires. If you plan to change the offset you may need to remove the rear crash bar, but it's sounds like that's very easy to do.
Overall minor changes if any to move to 33s. I don't know how this will effect offroad performance though. If you are going to push your articulation you may get some rubbing.
KnoxGnater
Nat
Knoxville, TN
1934 Ford Roadster Pickup, Bronco Badlands
SAS = off road capability, which you just said you don’t need. (No shame in that). You’re interested in cosmetic items so yes you can accomplish that via less expensive mods. You also improve your build chances.
I don’t say that just because you dropping SAS improves my chances too 😂.
Rayder
Brighton,MI
F-150
I think you are a great candidate for just doing rims and tires and dropping sas. The real benefit of sas on a BD is all the extra off road kit, but if you are using it as you say that is a bit of a waste.
Lilj4425
Jacob
Greenville, SC
2021 Badlands Bronco
I originally had SAS on my Badlands order but decided to drop it. Not needed on that trim and saves me a few thousand dollars. If I was getting Base up to Outerbanks then I would get SAS due to those trims having smaller tires and less off road features stock.
HoosierDaddy
__ Eric
NW. Indiana
For your stated uses, yes, you can easily and cheaply jump up to 33's.
285/70-17 (32.6") will fit no problems, no lift required ... according to those who have done it already. You're only jumping up about an inch in tire size. (265/70-17 = 31.6")
The 4.46 gearing will be GREAT for 33's.
I'm thinking about 285/70's or 285/75-17 (33.8") on my baseBase. I MIGHT have to lift a little.
Matter of fact, regarding the 34" 285/75's ..... https://www.bronco6g.com/forum/thre...on-285-75-17-bfg-m-ts-pics.20087/#post-719614
ilbastarge
Northeast
Tesla X
But the Sas is more than just wheels, tires, and lift… so you have to weigh if you want any of the other things (including different diff gearing, wider flares…) or the additional capabilities (longer suspension travel).
This is the bane of my Bronco understanding: i think because Mama Ford never detailed it out. However, Ford is here now: @Ford Motor Company , would you PLEASE detail the differences in your 3 suspensions for the masses? Heck, with us UNDERSTANDING each of them correctly we might even be able to adjust build and reduce your constraints.
Basic - Badlands - Squatch
Some thoughts are that Squatch is rentals a Badlands but with some type of upward travel limitation to prevent tire-body contact.
@Ford Motor Company - please advise!
HoosierDaddy
__ Eric
NW. Indiana
Just to add, I saw a 33" Badlands next to a Wildtrack at the auto show .... you're right, the Badlands is damn impressive and there really was very little difference in "presence".
Bronco-ocnorB
Luke
DFW
Ford Flex
This has been a struggle for me as well. I have bounced between Big Bend with rear locker and Base Mansquatch. I am an Oct reservation and wanting the MIC (I guess!) So it will be MY22 for sure. At this moment my builds are basically equal in cost with what I will add and do aftermarket. With that, I am going to sacrifice any interior upgrade for the drive stronger drivetrain and factory lift. But the struggle is real with this one and I am completely with you on your use. Agree with the above as well with the 4.46 working well with the 33s. Best thing is to get what you want and are happy with!
North7
North Texas
SUV
You must have missed my thread.
WARNING: Deep dive technical details ahead!
The Definitive Guide to 2021+ Bronco Ride & Lift Heights with Wheel & Tire Sizes
Ford Bronco Rethinking SaS 1623675007580-
iamchewby
Chewby
If you don't need the off-road capability then don't spend the money for it. I would avoid the fiber disk lifts for lifts. As soon as people start swapping their sasquatch suspension for Fox and Icon you'll see a lot of stock Sas suspension on the used market for cheap, wheels and tires too, you can scoop that up and have the look without the price
jedmisten
Joseph
CA
Ford Ranger and Ford Flex
But the SAS looks so good! Just left the dealer and saw both a Beg Bend with and without the SAS. SAS is the way to go. I know that sounds stupid, but the Bronco looks so much better with the larger wheels. Yes, 33’s looks good as well, but proportionally the 35’s look still look better. If you are building a truck straight from the factory, you might as well get what you like. Just my opinion.
Ford Bronco Rethinking SaS 47A82C1F-A0D0-48B1-9B7F-E934810C7EBF
Ford Bronco Rethinking SaS F3E71A3B-EAA2-4F3D-98FC-48123F03F4ED
Sighlense
Upstate NY
2015 Mustang GT - 2022 Bronco Wildtrak
Ford Bronco Rethinking SaS Yes
