Remote start seat heat?
Dom
Dom
Phoenix AZ
2000 Ford Expedition, 2013 Ford Fusion
Maybe a blown fuse?? Or do they get hot after you are in the vehicle?
Toffen
Toffen
Rick
Halifax, Nova Scotia Canada
2010 Jeep Wrangler 4 door
And to confirm, the steering wheel doesnt heat either? What is the outdoor temperature at the moment of testing? From day 1 my heated steering wheel and seats were set to "Cook the passenger" mode during remote startup. Odd.
The steering wheel was warmish (it never really gets hot…)
Our outside temp is 0* c
(32 f)
Once inside the truck and I push the start button, the seats warm up…
Butzy
Butzy
Brookfield, Ohio
f150 & bronco
There's a climate setting. You can either set it to "remember last setting" which will go to the temperature you had when you shut the vehicle off and the same seat heat settings. Or you can have it set to "auto" which automatically sets the temperature to 23C (will heat in the winter or cool in the summer).
This👆
Butzy
Butzy
Brookfield, Ohio
f150 & bronco
I cannot find any “climate” menu…
I cannot speak on the Bronco (awaiting delivery)but I have it in my F150. Not ideal settings either way typically. It was on the gauge display, not the infotainment screen
HeliPilot
Kenny
CT
2022 2.7L SAS
Wheel and seats warm up on mine when I remote start. If I leave my seat heat on low, it will be on low when I get in, unless the temperature is below whatever threshold Ford has set up. If its cold enough, the seats will default to high.
Toffen
Toffen
Rick
The Bronco doesn’t have the same “settings” menu on the gauge cluster…
Butzy
Butzy
Brookfield, Ohio
f150 & bronco
that sucks. Hopefully someone in here can help.
Butzy
Butzy
Brookfield, Ohio
f150 & bronco
NeoS281
Bellevue, WA
2024 Bronco
@Toffen I may have figured out the problem (try this and let me know if it works). Go to Ford Pass > Vehicle Settings > Remote Start Setup > Seats > and switch from Off to Auto
Ford Bronco Remote start seat heat? IMG_2437
Ford Bronco Remote start seat heat? IMG_2438
Ford Bronco Remote start seat heat? IMG_2439
Toffen
Toffen
Rick
For some reason, your menus look different than mine…
Ford Bronco Remote start seat heat? 8CFE174C-E406-42FF-A5A0-47F2EF08361F
Ford Bronco Remote start seat heat? 4C1C0E2C-31C4-4225-ACDA-F88C33184D32
Ford Bronco Remote start seat heat? 8C44B58C-506E-4BD5-8C57-DDBF31242908
NeoS281
Bellevue, WA
2024 Bronco
You should have a Vehicle icon somewhere under Settings. My screen might look different since I have Mid package and not High/Lux. Looks like you can move the ellipsis over for additional options/settings on this screen
cowman
cowman
texas
ford
I have High Package and mine looks the same as yours Jared....
