Rear View Mirror
BadRobot1031
2023 Bronco
I have a 23 Raptor less then 400 miles and the rear view mirror turns dark after start up it seem's like it's in night mode all the time, as soon as the engine is turned off it goes back to clear. anyone have any suggestion's on what would cause this before I bring it in to the dealership.
BadRobot1031
BadRobot1031
2023 Bronco
here are some pictures before I start it and after, also the picture of the front windshield, not that clear because of inside garage.
Ford Bronco Rear View Mirror IMG_1948
Ford Bronco Rear View Mirror IMG_1947
Ford Bronco Rear View Mirror IMG_1934
Ford Bronco Rear View Mirror IMG_1936
Ford Bronco Rear View Mirror IMG_1933
Ford Bronco Rear View Mirror IMG_1935
Beach_Bum
St. Augustine, FL
2023 Outerbanks Bronco
Did you have tint applied to the front windshield?
JTS0625
Jordan
Louisiana
Honda Element, Dodge Charger
It's upside down! Mine was flipped from the factory as well. The sensor is being blocked from light and so it stays in night mode. Just spin it around to where the small circle in the middle is at the top!
BadRobot1031
BadRobot1031
2023 Bronco
No I do not
Beach_Bum
St. Augustine, FL
Nice catch.
BadRobot1031
BadRobot1031
2023 Bronco
Thanks I will give that a try
Robs
New hampshire
2023 Black Diamond
JTS— which is the thing that is might need to be flipped around ??
Beach_Bum
St. Augustine, FL
Mirror itself needs to be rotated 180 degrees. When they are installed at the factory, sometimes they are inverted.
