rear 12 volt port timout
acbaldwi`
Aaron
Golden Co
2002 Jeep Wrangle, 2005 for Explorer, 2021 Bronco
Does anyone know how long the rear 12 volt port stays on after the engine has been turned off?
TXBoy79
Trevor
Lakewood Ranch, Fl
Ford F150
Should shut off immediately. My ā€˜18 F150 12volt doesn’t stay hot and neither do my USB ports once I shut it off and exit.
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
acbaldwi`
Aaron
Golden Co
Rus-T
Rusty
FL
Ford Bronco Black Diamond
It’s around 30 min. I have a fridge running off of it, and I can open the tailgate and well tailgate:) I’ve never timed it, but it’s around that I would say.
Kameronatm
Kameron
Bronco Badlands 4dr
"we found that the 12V power source in the rear of the Bronco will stay powered after vehicle shut off for 1 hour, and the factory rear light will stay on for 10 minutes."
source:
mbagne
Placentia, CA
Mach-E GT
source:
The presenter in this video talks about it at the 10:20 point.
Texasgrillchef
Gary
Dallas, Tx
Bronco Badlands, Harley Trike, Mustang
source:
There is an option in FORScan to update PowerPoint to a maximum of 18 hours.
However it is unknown if this setting has any affect on the cargo area 12v outlet.
da_jokker
Jeep Wrangler JKUR
And do we know the Bronco will be smart about it, and turn it off if the battery gets too low? Or will it leave it on for 18 hours even if it kills the battery?
Tishomingo
CA
2022 Bronco
Was able to disable the PowerPoint timeout with Forscan instead of adjusting the time.
Now my Dometic fridge stays on as long as it's plugged in.
Ford Bronco rear 12 volt port timout 20230416_183727
Ford Bronco rear 12 volt port timout Screenshot_20230427_195135_CFX3
da_jokker
Jeep Wrangler JKUR
I've actually got used to the timeout and use it to my advantage. With my fridge plug into a power station and the power station plugged into the Bronco, it's actually working out really well. Power station stays charged up while the Broncos running and for the X minutes after the Bronco has been turned off.. fridge stays running whenever I need it without any sort of power interruption because of swapping plugs.
MNBigfoot
MN
I'd prefer it to always be live, but 18 hours would be great, thanks. If anyone has a link to how to do this, please advise.
Tishomingo
CA
2022 Bronco
Using Forscan, change PowerPoint from enabled to disabled. Then it will stay hot.
AustyPosty
Austin
2 Door 2017 Jeep Wrangler
How exactly sid you do that? I’m trying to do it but I only see the option to change the time
Tishomingo
CA
2022 Bronco
There are 2 options to select in Forscan regarding timeout. Above the one for the actual time, you can enable/disable.
