BroncoSarge
BroncoSarge
Jeffrey
Fort Bragg, North Carolina
I am going to install my setup on the wife’s CO Badlands soon. I will take some photos of the bottom plate before I install the winch plate and of course will take one of my camera view. Anything else y’all want to see?
akturbo
Seattle Eastside
Well, I take back what I said, I'm digging the setup. Granted, I haven't gotten to actually use the winch since I haven't gotten stuck, so I can't speak to the strength which is still my concern. JCR bracket, BAFM control pack, KR Offroad Front plate bracket make it a clean install. JCR view is perfect and ACC still works.
Ford Bronco RC High Winch Mount & Winch Install w/ Control Box Relocation IMG_4075
Ford Bronco RC High Winch Mount & Winch Install w/ Control Box Relocation IMG_3689 - Copy
unfortunate
NA
Very nice setup! Just finished mine up over the weekend, I relocated my control box to the passenger side since I don't plan on running a compressor. I ordered a JCR camera bracket as well, hoping to see that soon.
Details on the switch bracket? I mounted my apex winch but haven’t found a good way to mount the switch. Yours looks good.
Ford Bronco RC High Winch Mount & Winch Install w/ Control Box Relocation 42A4B0DA-BDC9-40D0-A6C2-8B2F9E6FB263
dcg2
Don
PA
Honda CR-V
Nice job with the control box... that damn thing is huge. I ended up taking it apart, reconfiguring it, and printing an enclosure for it.
Ford Bronco RC High Winch Mount & Winch Install w/ Control Box Relocation 20220703_114258
SCBronco1
Peter
2019 F150 Lariat Fx4, 2012 BMW X3, 2011 Escape
I still think that I am going with the RC hidden winch for the 2.7 now that it is available. I like the not there look.
Yours looks very clean and wicked however!
Vellicate
James
2018 F150, 2014 Flex Limited
Homemade bracket, cut and welded out of some scrap I had laying around. I copied the basic design of an ARB compressor mount, made a support to the firewall, upper coilovers bolt and to the passenger fender. It's not the prettiest but it works. I didn't take any pictures of the bracket by itself but I can try to get some better pictures of it installed.
shawn6107
Shawn
Tuttle, OK
Ford F250, Ford Expedition Max, Chevy Silverado
I have the same mount on order along with the rough country winch. The control box relocation is what I’m trying to figure out. Their control box is huge. I’ll probably just have to build something for it once it’s in my hands.
etmccaus86
Evan
Motor City
'22 BaseSquatch
Do you mind me asking what you used to relocate the solenoid pack on that winch?
I have the same Apex waiting to be installed here, and should have a winch mount in my hands by end of the month, so I'm starting to actually plan this installation...
Vellicate
James
The Apex winch will include most everything you should need to relocate . I made my own bracket out of scrap steel I had laying around. My winch came with 3 ft cables to go from the winch to the control box, which were too short for where I needed to go. I was able to find 6 ft 2awg cables that worked out pretty well. Others said you might be able to have the cables made at a local auto parts store.
As far as the bracket goes, I didn't really make a template, just measured and fabricated as I went. I did use the design of the ARB bracket as inspiration. Others have just taken the guts out and put them into a waterproof electrical work box as the Apex control box is unnecessarily huge.
If you have any more questions, I will try my best to answer. Have a good one
cyberfalco
Tony
Conway, AR
2011 JK, 2000 Ram 2500, 1993 FZJ80, 1994 FZJ80
I am not a Rough Country fan but this is the simple mount I was looking for. Thank you for posting this.
BroncoSarge
BroncoSarge
Jeffrey
The smittybilt only needs longer cables. I went with the Warn kit cause the price wasn’t bad, decent length cables and the rubber end caps were black. Didn’t want red and yellow on my front bumper.
WARN 89960 ZEON Control Pack Relocation Kit
BroncoSarge
BroncoSarge
Jeffrey
This is the view fro the camera. Finally took some.
Ford Bronco RC High Winch Mount & Winch Install w/ Control Box Relocation 537B81A0-3FED-4875-BCBD-1DB450B6711B
Ford Bronco RC High Winch Mount & Winch Install w/ Control Box Relocation BB4D6DEB-5E98-4EFA-95DA-03AB6EA86197
Jdc
Jon
Massachusetts
Bronco Badlands
For those of you that have installed the RC winch mount, how hard would it be to remove/put back after you've done the initial install? I'm thinking about getting this but I don't want to run it permanently and I'm ok with the idea of spending an hour putting it back on for when I might need it.
