Raptor Running Board Brackets (3 Per Side)
CR_IN_UT
St. George, UT
F150 Shelby Raptor, Bronco Raptor, Jeep 392, 05 LJ
Does anyone have access to find the part numbers for the 3 brackets on each side for the raptor steps. I bent mine almost 45 degrees. Local Ford Dealer worthless so I would rather not go there if I don't have to.
CR_IN_UT
CR_IN_UT
St. George, UT
Is there a way to just look it up myself on a drawing or parts schematic?
j_marinelli
Spring Branch, TX.
Check out this post as I think it will have the part number you are looking for:
https://www.bronco6g.com/forum/thre...nders-flares-vs-ppf.58872/page-3#post-1729085
The boards show direct ship from the mfgr, none in stock, supplier shortage in the notes but do price. Not sure if these are complete rails with the steps and brackets but are shown per side. Weight is 18lb each and have a list price of $1,763.18 each.
Here is what it shows on a HVBOM. Top one is the service part number, bottom two are engineering numbers of sub components.
N2DZ-16450-ZA step assembly
N2DV-16470-AB (2) bracket/running board
N2DV-16470-CB (1) bracket/running board RH
N2DZ-16451-ZA step assembly
N2DV-16471-CB (1) bracket/running board LH
CR_IN_UT
CR_IN_UT
St. George, UT
I appreciate it but that's not it either. When I look up running boards or steps the brackets don't even look the same. The Raptor has different ones because they are removable steps.
CR_IN_UT
CR_IN_UT
St. George, UT
Thanks for this.
The brackets that are bent that I need are still in pink showing a light blue bolt (HB2) going thru them. Does that mean that the brackets are part of the removable step? The brackets are removable from the bottom of the step and are removable from the rock rail so I would think that they are able to be purchased separately.
