Raptor Rear Diff Cover (want drain hole!)
swamp2
I've been googling like crazy to find something but no luck. Looks like nothing is made yet. Too many terms too; Dana 50, M235, 9.25", Advantek, Spicer... Haven't been in the Jeep community prior, so this jargon is a bit new. I guess since the OEM part (nice cast aluminum) looks like it is Ford provided, not Dana, and since Raptor volume is low, maybe they (Spicer?) decided to not offer one? Hopefully, someone in the aftermarket will make one. Not having a drain hole is a bit of a crime IMHO. These are not lifetime fluids, wheeling hard or not...
On a related note the front drain plug for the M210 diff (regular and Raptor) are magnetic. Also the rear fill plug on the regular Bronco (Dana 44) is magnetic as well. I suspect the Raptor rear fill plug is also magnetic but looking to verify. Lastly, the Advanced Transfer Case also has a magnetic drain plug. Magnets everywhere on the Raptor.
APEX REX
23 Braptor and 21 2D Base 2.7 SAS
I'd like one too. Like the F150 Raptor, I'm hoping Ford Performance will have a version out shortly for our Braptors.
swamp2
swamp2
Tor148
Tor
Cape May Court House, NJ
23 Braptor Bk, 21 FE RR, 15 F250,
Watching this thread. I have been looking for the same. I have the ford perfirmance cover with drain for my FE but want it for the Braptor as well.
Breptar
Max
Los Angeles, CA
For non-Raptor Broncos only... (not to mention $750...)
I thought I had seen a braptor diff cover, but you’re right, it could have been for the regular bronco. You have to remember that it is a billet cover and anodized too. Still expensive, but a nice piece.
raptorusmaximus
Horicon Wisconsin
2012 F-150 Raptor
I just replaced my fluids this weekend, I thought the rear wasn't too bad. I will say that the sway bar is in the way so I need to get a ratcheting 13mm wrench. I really like the reusable gasket though, makes the job much easier. Yes, both front and rear plugs are magnetic as is the filler plug on the trans case.
I went royal purple 75-140 both front and rear after checking dana's website.
vrtical
Doug AI
GSMNP, TN
Fords
^^^ same not sure why FP did a nice cover for the braptor but no drain plug kinda stupid, but having the reusable gasket makes it easy.
